The Ultimate Baby Dehumidifer
Was in my local Do-it-All (Home Depot) store at the end of the day to pick up some bits for home.
Saw on a shelf a little box about 12" (300mm) high x 6" (150mm) wide x 5" (125mm) deep which contained a Dehumidifier operated by a Peltier device. It was priced around 20GBP.
Powered from the 230vac mains through a 9vdc transformer, so it could run, briefly off a 9v battery if you got desparate :rolleyes:
The duty was claimed to be 250ml at 30°C 80%RH.
I think it was suggested for use in a clothes wardrobe. Just wonder what the duty will be in our northern climes at this time of the year :D
Re: The Ultimate Baby Dehumidifer
Brian_UK
Hi Brian_UK,
Can you share the brand?
Would appreciate if you could include the website or link.
Thanks in Advance.
Winfred :)
I'll see what I can find out Winfred.
Unfortunately the website doesn't give too many details but here it is:-
http://www.focusdiy.co.uk/invt/196311
If your baby is that wet you should change its nappy (diaper), not stick it in a dehumidifier!!!
cheers
Andy P
Well, that's certainly a different viewpoint! In another thread we were discussing ammonia releases, and here we are back to that again.:D
Brian_UK
Thanks. :)
Actually if you do a Google on 'peltier dehumidifiers' then quite a few come up ;)
