Freon leak Monitering System
Hello, Every One
I am looking for ***** leak monitoring alarm system, Could be one or multi sensor.Please let me know,which one is good one and have good Experience with it
*****: R-404A
Application: Walk in Box
City/State: Burbank/California, USA
Amrit Ghumman
Re: Freon leak Monitering System
A number of manufactures have ***** sensing monitors. Some are refrigerant specific, some are general.
Gensis makes some as does Honeywell.
They provide multiple sensing points and alarm levels for engine room applications. Outdoors is a problem due to wind currents.
Mike do you remember the name of the monitors Frank Weirts had before it was bought by Honeywell?
ken
try typing parasense into google(other search engines are available) for a multichannel leak detector. alternatively hussman via stonegate instruments used to do a single channel leak detector.
the parasense detectors have varying degrees of sensitivity and are very reliable.
most good wholesalers will stock a single channel detector.
It was Manning....the old gray matter is getting a bit fuzzy...
K
Bacharach has good refrigerant monitors and you must specify refrigerant being detected.HGM,RDM styles are what I use.They are also available with a 4-20 ma card for communicating to a energy management system.You can order with audible alarms and strobe lights.
We use a parasense system and a TQ Environmental both are multigas multisensor systems. Both are pretty reliable so I guess the only split would be the price... I haven't got a clue on that I'm afraid.
