2 Attachment(s)
the transformer suddenly blew up..
Hello my friends. Recently I inspected a ceiling Carrier indoor unit and after setting that in operation suddenly the transformer of the indoor pcb blew up. I didn’t know why this occurred since the unit had been working for 3 seconds at least. The wiring between indoor and outdoor was correct. I suspect the humidity caused the problem since the unit was stored for about 3 years in a room with no light and high level of moisture. What is your opinion? Is there a chance after putting on operation the unit to have the transformer suddenly blown up?
Attachment 10999Attachment 11000
Re: the transformer suddenly blew up..
probably is moisture- as the fuses would have protected the transformer from grounding- also allow the contactors coils for fans,compressor , heaters to dryout otherwise theyll be more to change
The cables appear to have been cut, was this before or after it blew?
Sorry, but this unit is power supply of 230/3/60 . It's possible on your site?
