has anyone any ideas.i dont usually work on domestics,but a mate has an american fridge freezer and the ice maker has stopped working.are there infra red lights which stop it when you open the door,or is this a major problem.
On most there is a leaver of some type that turns the ice maker of when it full, they some times get jamed.
Is there any ice in the tray???
its also worth putting a meter on the water valve on the back as some get a build up of limescale and block the system.
it has Infrared Sensor Ice control
i have checked water and cut off bar and both seem o.k.thanks brian
both should be on
is it likely to be a panel problem or faulty sensors.thanks
