Re: LG Artcool water problem
Check your refrigerant charge, suspect its a few 100 grams under...
Was thinking the same thing as stefs cruiser, sounds like may be a little short. That doesn't explain though the 6 month intervals between the problem, or is that just when they alert you of usage?
You guys must have some reason to think this.... care to say what the theory is? (If you are thinking heavy build up at the point of entry into the evap - then no).
