Re: System sizing for heat and manual J
My advice, which have cost of electricity in mind, would be to consider buying two duct type split-system inverters of some Japan manufacturer like Daikin, Toshiba, Fujitsu and you could heat your home without much need of additional heat from electric heaters all the way to -10 to -15°C outdoor temperature.
Example:
http://www.fujitsu-general.com/globa...uct/index.html
Install a geothermal heat pump is the answer. maybe
Best regards from
yangchenchen
If you oversize it for heating have a dehumidifier on hand. Get an April Air whole house model.
You guys are right. But the payback on best choices can be fairly long, way longer than I will stay here. My motivation to replace the old gear instead of patching old stuff is because I expect energy will cost much more in the future.
I looked at ground sourced systems. I have the land and I have no objection to stripping the dirt to set the pipe coils. The choices of contractors are pretty limited so far and they are very expensive. For instance, three systems here can be replaced for around $23K-$25K with good air sourced gear. The wild guess from a ground sourced contractor was $60,000+ nearing $70,000. I may be misinformed, but excavation, laying pipes etc doesn't seem like it should be that exensive, even five or six feet deep. (wait till he discovered the rock though, lol) There's a lack of competition in this field that makes this choice very costly. It seems like the equipment itself is very reasonable. If I would live here ten or fifteen years more, I would study that option more closely, because I expect electricity here to rise from 9-1/2 cents to 25 cents per kwh. My use is 32,000 kwh/year with old gear that spec'd at hspf 8.75.
The inverter technology looks attractive. It can adjust to meet peak loads while providing dehumidification during light loads. The efficiancy is somewhat better too, perhaps by eliminating the cycling. This inverter technology has limited distribution here in the US. In the larger sizes, it's really expensive as well.
I made the hard decision to up-size to meet heating needs on floor one by adding 1/2 ton. This house is well sealed, so I hope my gamble works out for the latent heat side. If the first floor becomes humid, I'll add the system dehumidifier Abby mentions. The lion share of my expense is for heat, so keeping the heat strips turned off is key.
Hi I Need Some Easy Way To Size Ducting In A House ,thnks
