As above, has anyone used them, are they worth buying?
We have the swaging set great for soft drawn copper, you will need to anneal hard drawn to use them.
They do work well and they don't split the tube like expanders, never tried the flare version.
I have both the swagers are great deeper than a standard swage the flare unit not so good only really use them on a unit when there is no access for eccentric flare block
