Fujitsu ASTA24LCC domestic A/C removing drain hose
I'm new here as a found some ggle links that suggest I may find some knowledgeable's that may provide me with some assistance. I have searched; YT + ggle + fixya +......++++. I have been at this for days and I'm at my wits end to find a (any/reliable) solution.
The (indoor) AC is as noted. The fan/blower motor bearings are knacked and I wish to remove the motor and replace the bearings (yep can be done) - new motor ~$200 (& $450+ labour), new bearings ~ $20-30. Plus the motor is a squirrel cage (induction mtr), very electrically robust, so re-using no probs.
The mtr lives in the drain pan assembly and with an easy strip down (which I have done) the drain pan separates from the condenser assembly (drops down). Problem being is that the d/pan drain hose going through wall to outside is stopping dropping the d/pan completely. LH side can separate from condenser head but RH side caught due to d/hose. Does anyone know how to remove this hose, please oh please? Apparently it is fixed to the pan with a screw (may also be glued?) but only having < 50mm between the wall and pan hose entry, cannot see + also can't get any tool in there to remove if there us a screw. The hose is flexible (it seems) and has a (insul) covering. Can this hose be cut further down and re-joined (if have to)? Would very much appreciate assistance with removing this hose, once done everything else pretty easy stuff...Thank you
Re: Fujitsu ASTA24LCC domestic A/C removing drain hose
Those hoses are genrally a push fit, albeit a hard push, try a flat blade as a twisting lever at the top of the hose where it fits the drain pan.
From experience I have only ever known these to be a push fit and if you look up the parts list you
can see the drain with the push fit ends.
I don't think this model should be any different so as Brian says the drain hole fitting is fixed to the
tray and the drain should be a push fit over that (but there is always a first time).
What you call the condenser assemble is the evaporator (the condenser is outside) the drain tray
is flimsy if you are rough with it but if you can hold the pipe with grips and slowly pull and twist the
tray it should come free.
Rob
Ps if you are capable of removing all the components and replacing the bearings
why not just replace the whole motor assemble yourself and have done with it?
You won't incur any labour costs that way.
But be warned one way for AC engineers to make money is to follow people who think
they can do the job cheaper themselves.
It is not the dearest option to get a professional to do it right first time, plus you have warranty.
Rob
3 Attachment(s)
Hi Brian, thank you for your reply. Indeed sir, oh, I just wish it were as you described, I would have had it all done and dusted, 10.3 days ago. Yes, I've been trying to get info and advise for this period. I can't find install/service manual, unless I sign up for "free" with c/card-no trust in this.
I can find some Fujitsu docs which have wall mounted units (not this one) which advise hose is attached with what appears to be a saddle(?) clamp and screw. Screw is not side mounted but goes straight in, same direction as hose. This is also backed up, by, there is no cut-out at the side to get to screw as installer would have used this to attach. Have also chanced upon some discussion where others mention pushed on and glued. Also in text others mention steps to take off d/pan, saying "remove drain hose" as one of the steps but don't tell you how. So if I go in there and heave on it I will stuff up the hose. Getting another hose back on will be another pain. So I'm trying to get as much correct info as I can so as to not cause more issues.
The d/pan is encased in polystyrene and the d/hose enters a hole in this and goes all the way to the plastic case inside (depth ~ 45mm)...so you can't get to it, can't see how it attaches (inspect mirror/lamp-no go), no levering with s/driver etc. Photos are attached.
AC shop, I got out initially, thinking their "service" would separate this d/pan to clean (yeah, office "Susan" said they would-but nah) only removed outside cover, fluffed around (temp/current check), charged me $140. I called later concerning d/pan, d/hose removal + mtr ~ $650. Asked how to - for d/hose removal, advised most are glued so they cut further back as hose goes out through wall to connect to solid drain tube (exits outside to ground), then re-join. So if no others can assist this may have to be the way. However the visiting AC dude did not seem too cluey so I'm cautious. However appears to be the only option or pay.
Anyone have an install/service manual for this ASTA24LCC it would be gratefully appreciated + still seeking knowledgeable advise. I'm not in a financial position to afford the shops cost + I've stripped it to the stage where once d/hose off I can complete and re-assemble. Thank you
Thank you Rob...I respectfully hear your words and value what you have stated (thanks for correction on h/ware terminology). And I may have to look at the the AC Eng option. However, I'm out of work (E/Eng) at this point, so $'s tight but heaps of time + have taken on issues above this with no probs. All that is stopping me is a damn hose/lack of info. Reason for mtr repair (and not complete swap) is as noted from experience/knowledge, squirrel cage mtrs, rarely electrically fail. Bearings always eventually fail, easy to replace and cost effective ($20-30) compared to $200 for a new one (+ 20days wait to get). I also like to re-use where possible and not waste resources. Thank you for you tips on hose removal, I may chance it...? Many thanks Rob
Tigercat
Oh and that must be the politest rebuttal in internet history. :D
I like you. :D
The drawing I linked is slightly different in model but it give you an idea of what the drain looks like.
Rob
If you look on page 14, item 50, you can see a small endplate with a hole in it. If your hose does not have one of these then it is just a push fit. https://guidessimo.com/document/3212...manual-22.html
To replace the fan scroll, which I think is your original enquiry, then you are going to have to remove the drain pan assembly, the electrical pcb housing, the fan motor AND lift up the evaporator coil to gain access. This is quite a tricky process which, not only leads to "coil rash" :( (cuts to your skin from the fins), but can lead to fracturing the pipes. Not really a job for the untrained. Doesn't mean that it can't be done but be aware of the pitfalls.
If you decide to tackle this yourself, then good luck, and don't hesitate to drop back if you get stuck.
Tigercat, having looked at some installation details I can see your problem with needing to access that screw holding the drain hose in place.
Knowing that you have knowledge and tools my next question is - are you up to drilling a new hole in the wall to run a new drain hose?
My suggestiton is this:-
1. Cut the existing drain hose as far from the drain pan as possible.
2. Remove the drain pan from the unit and unscrew the existing drain locking ring.
3. Remove the blanking plug from the other end of the drain pan so that you can fit the repositioned drain hose.
4. Fit the blanking plug in the old drain hole.
5. Make a new hole in the wall to accept your new drain pipe.
6. Make up a new drain pipe to connect with the old existing part that you removed/cut off.
7. Fit the modified drain pipe to the drain pan.
8. Refit drain pan and test run some water through the pan.
9. Have a well desreved coffee or something stronger.
Hahaha good onya mate; dear Rob, I've taken a shine to you as well. Nah, mate, that's no rebuttal. Just a sincere and genuine statement to say thank you for your advise and I'm in thought mode with what you and Brian have suggested. You and Brian are experienced in this area...me = 0, so I'm definitely in the listen up mode.
However my thought process is: 1)I heave on the hose and stuff it=more issues to fix it+new hose, Engineer heaves on it, stuffs it, extra labour+ exorbitant cost new hose + hose still has to be removed (cut and re-joined on outside wall) to re-join. 2)I heave and it comes off-yippee=$0, Eng heaves on it-still=$+450 labour charge. 3) I decide to cut hose (further along) where it routes along the outer wall, pull through wall, then re-join after-none of the above will occur, Engineer rocks up and says, yep I need to cut and re-join (as the advise given, via your ph call to us-which I was not overly trusting but options are limited), again still=$+450.
So, 3) has (appears??) the lowest risk for both. Hose is accessible on outside wall and is easily doable + need to (remember haha) tie cord around severed end to pull back through wall when pan re-installed
If hose is cut on outside wall (~400mm from where it attaches to d/pan) and pulled through the opening in the wall it will resemble the image in the manual you supplied, pan should then come off. I also found and browsed manualslib but the operator manuals do not show how hose is attached to pan...service manual (not available there/anywhere) would do the trick...found one prior for a Fujitsu (similar arrangement as mine?)
http://www.fujitsuklime.com/wf-doc/f...ion-manual.pdf
Page EN-4, shows how this model attaches drain. And even in this case, how to get to the fastener when unit is <50mm from the wall? No special tooling is noted to achieve this. Still looks like a cut and join unfortunately? I do hate cutting stuff though, always like to avoid.
Hey Rob it's great to be liked, haha, and I think I understand your sense of humour. Great to have a banter with you sir...Tigercat
Hey thanks Brian. Yeah mate it is a PITFA. Yeah mate, I have a feeling it has this locking ring arrangement + funnelled down inside a 45mm styrene cavity until it meets the attachment point on d/pan. You are also where I 'm at. From the pics I sent the drain hose is visible going through wall to the d/pan. I was going to cut/remove unit drain hose (as supplied d/hose is not overly long) where it meets up with pvc (to drain to outside) on the other side of this wall (access no probs). Tie a length of cord around this end, then go inside and pull this hose through (with cord attached) the wall hole. It's a double brick wall, so approx 20cm distance from inside to outside wall + hole is large with space to maneuver hose through. Hopefully fix mtr issue, attach hose to d/pan and pull hose, via cord back through hole, refit d/pan. Haha, theory is always a tease though...
I very much appreciate your detailed, informative suggestions Brian. I could not go wrong in following what you have outlined...thank you
Thank you Frank for the info. I can't see up inside where the hose attaches to the d/pan, it's buried in 45mm of polystyrene <50mm away from a wall. I sent Brian_UK (my first reply, so top of thread) x3 pics which show the situation. Yeah mate AC is all stripped down as you have outlined. Removing d/hose and all should be good to go....haha, and that sir, is where I'm caught and yes I'm a bit hesitant; I'm sure I can fracture pipes better than most ...very much appreciate your input and guidance, your points are noted, as I am very much untrained...Thank you
What you will find is that the plastic drain pipe which is moulded as part of the drain pan, travels through the polystyrene so that the drain hose can push onto it. The drain hose doesnt extend into the polysyrene.
Have a close look at the other end of the drain pan that currently has the stopper in it and you should see what I mean.
The drain pan is moulded this way so you can choose which end to attach the drain hose to suit your installation.
You can remove the drain pan with the hose attached so that it swings down out of the way but in my experience it is best to remove it to change the fan rotor.
I'm not sure that the drain hose is going to be your biggest problem on this project.
Yeah, sorry Frank I did not choose my wordage correctly. Post #13 (to Brian_UK) explains better. Yes, the hose does enters into the cavity moulded into the p/styrene d/pan "shroud" and goes to spout on d/pan (can't see it but assume this is the way). And yes sir either end of d/pan can be used for drain purpose, I did note the LH side option. Indeed I thought the d/pan would swing out with the hose attached as you have suggested...but alas it did not.
Haha, that's why I'm chatting to all you nice folks because the brstd didn't/wouldn't do this, swing down. All the attachment points have been removed and the d/pan needs a gentle pull down to separate it from the evaporator (thanks Rob), from what I have gained from discussions on web (but no instructions given though-haha), just general chit-chat saved on forum boards from a few years back.
Sounds like you have had experience with this situation Frank?
Frank, I'm pretty sure you're spot on mate! It also may not be my biggest problem. Thank you Frank. I'm going to wait for a wee while and gauge all my options before any attempt(s)
What is on the other side of the wall where the drain pipe exits? Can this be disconnected to allow the original flex hose to be pulled back?
When we install these units, the lower half of the unit is pulled away from the wall on it's bracket to allow us to make the pipework connection. Seems strange that yours is only 50mm from the wall with no 'play' to allow access to the joints
Hi Frank, yes indeed, that was what I had in mind. Yeah, I just don't think I had the guts to push areas around even though I have read (discussions) noting that the evaporator should move up a bit on it's mountings, allowing lower half to "drop down". I'm wanting to approach with the low risk mode if possible, I can fracture piping better than most I'm sure, haha.
Below is what I noted to Brian in post #13, concerning what I had in mind...Thank you Frank, I appreciate your knowledge and info, we all closing in on the same "page".
Hi fruity.
I've emailed a few manuals to the address on your vcard. There's the install, service and technical manual and also a file for getting access to the motor on newer units which might be of interest although it looks you are pretty much there anyway.
They are from my company email and might go to the junk folder so check there if nothing turns up.
From what I recall I'm fairly certain it is a push fit donkey dik (correct terminology!) on those units. If you can get a mirror on the spigot on the left hand side to confirm there is/isn't a hole to screw it in should confirm.
If so it could well be the rubber/plastic has stuck together and best way is to twist it free although I can see that is easier said than done.
Cheers,
Andy.
Edit: correct terminology falling foul of the language filter but you get my jist. :cool:
Hello there Andy,
Thank you very much sir for the manuals (wow), very much appreciated. I have received them (x5 files) and will have a lookie. I'm hoping this ASYA model info has the same set-up as my ASTA(?). And also thank you Andy for your own info RE: hose fit. A massive help and a lot of effort from your side.
Yes from what I found here;
Not my model but similar, maybe...?
It indicates a screw access hole (on LH side as you suggested) combined with the styrene tunnel that accepts the d/hose. I cannot see this on the LH side (of my AC) but I can (I think) see an extra access port on the top (not side) of the styrene tunnel...will investigate further.
I will report back to this thread on what I find/where I'm at (have not tackled that pesky hose yet) ...as I'm still mulling over options and going through the fantastic response/info that all have supplied....
Many thanks Andy
4 Attachment(s)
Howdy all....ah, some progress. Got back to having some more play to drop that damn drain pan before moving onto the drain hose. And I now have the complete d/pan dropped to where I can get to the screws (hopefully??).
Photos attached...
Previously, the LH side dropped no probs (basically without any force at all). Applied the same technique to the RH side but it seemed snagged, did not want to force it. So hopped onto this forum to see what others could provide to assist. A big thank you to all for engaging with me, as I'm new here and posses none of the following; knowledge, experience and information, however you guys do and provided much need assistance, guidance.
Ok. so here is the go to ----> I re-seated the d/pan to it's original level position ie. d/pan re-engaged to the evaporator (LH and RH side flush and level set under the evap) all fasteners still removed. Instead of having a go at the LH side then trying to move the RH side. I gave a gentle firm pull/wiggle (first) to the RH side and down it came, the hose allowed itself to bend down with the pan....yippeee. The LH side then became a bit of a brstd and needed some extra pull/wriggle but at least the d/hose is not there, therefore not the reason for snagging.
Now just have to maneuver screwdriver(s) to get the mtr holding screws out and then mtr should be free. Will take more snaps when mtr out and dismantled....Thank you once again
Well done so far......
To remove the motor/fan rotor, you will need to split the motor from the rotor.
If you look carefully into the rotor middle at the motor end, you will see the head of an Allen key or screw. The rotor design is cast to allow you to introduce a tool to loosen this. This is how the rotor is attached to the motor shaft. Once loosened, not removed, you can remove the motor by sliding it out to the right, leaving the rotor in place.
These rotors are 'balanced' to prevent vibration, and are easily knocked out of balance by either chipping bits off while removing or not cleaning them fully. Due to the cost of the replacement part and from experience many times of stripping, cleaning and re-building these units during routine servicing, only to find that they then vibrate, I used to always install a new rotor assembly if there was a need to strip them down. Saves no end of time and heartache.
The opposite end of the rotor to the motor end has a small shaft that locates into a small bearing that is located into a rubber bush mounting. This was also always replaced.
Thanks Frank, no worries mate. Once I dropped the pan, Mr Newton assisted me with swinging the pan to the RH side and the whole pan came away (yes disengaged the hose as well). So yep, the hose was a push on (as others of knowledge have suggested). AC dudes advised it would be glued, many doc's showed it fixing with a fastener. So difficult to access and proceed.....
This hose and how it was attached was what was causing me all the issues...now I know how it goes, I'm pretty much sorted to re-furbish.
Yeah Frank, I did dis-assembled before I got your instructions, however, took great care with the blower scroll and the end bushing, have had experience with all this type of stuff before. I can see where they have added "weight" crimps (for balancing)to the scroll fan + it has some crude build up.
I note your tips RE: replace scroll/rotor + rubber mounted bushing and thank you. I'm in scrooge mode, so I'm going to v.carefully wash/clean scroll and re-use end bushing ($25 + 14+ days delivery/new)---I will re-grease end bushing with silicone grease. I can understand AC Eng replacing these though. But for me now knowing what I'm in for I will try re-using, as now taking apart AC is easy. If I run into probs can get back into it ok. Will get into splitting the mtr, swap out the bearings and all should be sweet. Thank you Frank for your valuable knowledge. I will post some more pics as I progress, hopefully may help others.
5 Attachment(s)
OK - for those that may have an interest. Drain pan removed as per my last previous post. I have stripped it down, making sure that electronics (tether to frame with a tie) is not left dangling via it's conductors. Cover with a protector, preferably an anti static bag.
I've cleaned all the covers with a very mild detergent solution and used a directional garden hose sprayer to flush off/clean. BE VERY careful with the d.pan and keep e'tronics upright in a bag out of the way. I could not remove e'tronics due to hassle removing stepper mtr couplings. Using directional g/hose sprayer hopefully (+others as per photo) stops parts other than the pan itself from being flushed/spayed. Also X2 pivot points for the louver system were seized, stopping swing from operating correctly - used silicone spray to release, after d/pan dry, lubed all these pivot points with this spray.
The scroll/blower fan was a chore as it was covered in tiny (<1mm) flies (hundreds of them), stuck on big time. Put this in my bath + water/deter with a thick towel under it to stop any damage when moving it around. I used a very mild detergent + paint brush + a gentle blast from the g/hose (after bath)Attachment 15812Attachment 15813Attachment 15814Attachment 15815Attachment 15816 to get those brstd's off. Installer did not seal hole in wall that's how they got in.
Fan/blower mtr is out (pic). Just above the Panasonic sticker a divot/gap is seen, there are x3 of them around mtr housing. This is where a "punch" of sorts (s/driver) can be placed. Bore a hole in a piece of wood to accept and support motor spindle, insert spindle and tap punch at divots with hammer and the cover should come away. Will post more once I get this mtr cover off (haha, hopefully).
5 Attachment(s)
Photos continued....Attachment 15817Attachment 15818Attachment 15819Attachment 15820Attachment 15821
And Frank's suggestion to replace with a new end bush is a damn good idea (thank you Frank) even though I was going to reuse the old one...new one makes good sense, even having to wait to get it.
Forum brd s/ware only allows x5 photos/post, so more photos in next post.
2 Attachment(s)
Fan/blower mtr removed. Cutout/divots in mtr housing noted above Panasonic sticker. Can tap with "punch" (x3 around circumference) and remove the aluminium coloured mtr cap....yep, there will be a circuit brd under this + top bearing. Will post more when into mtrAttachment 15822Attachment 15823
Now you know why we servicee technicians always looked forward to a full service on a split when it is mounted in a shop or office with minimum working space and limited time.
Glad to hear that you're making progress.
Yeah Brian_UK, hat's off to all you AC Engineers. I have far more time to play with this AC. All of you professional's will be on a time budget. And I appreciate why you would swap out old for new - time, difficulty and you need to supply a warranty...can't do that with old refurbished parts.
Sheeez, I'm glad I won't be at this again too soon...haha, have not got it back together yet and it might knob itself when I test it...has been good learning new stuff and meeting others of knowledge though...
A sterling effort so far, those Fujitsu drip trays aren't for the faint hearted!
The difference in the model number denotes the region or voltage supply so you are all good there.
I've stripped similar fan motors just to take a look and bearing replacement looks pretty straightforward. Like you say there will be a circuit board in the motor but the rotor will pull out easy. Not sure about the rear bearing, not taken one of those apart but guess that cover pops off somehow.
Cheers,
Andy.
Hey thanks for the encouragement Tayters (and Brian_UK). And yes you are spot-on RE: manual mod#'s. As I had a quote for mtr replacement, at my request, just prior to me attempting. And your mod# (manuals) is also stated on the quote together with my mod#, thanks mate.
Haha, yeah that drip tray does have a lot going on.....
Indeed, cct brd will have some solder points to remove. Then brd can be removed (needs to, for bearing clearance) from mtr casing and the rotor will come out completely, with, front and rear bearing retained on the shaft.
Been a bit crook, so have not split mtr. Maybe tomorrow? Will add some pics soon
Struggle on dude, you'll get there. ;)
4 Attachment(s)
Ok my AC friends, here we go with the split. Bore hole in a some wood to act as a holder for mtr shaft, deep enough (+ diameter just > than shaft) to hold shaft but not too deep to stop cast mtr cap from moving down. I must thank a Y/tuber for this idea.
Put some datum points (marks with screwdriver/indelible marker etc) that will allow cast metal cap to align correctly with the rest of the mtr body when re-assembling. As there is a driver chip (white mark = heat sink paste) that needs to be resting on metal cap (to dissipate heat)+ always good to re-assemble in the same orientation as originally assembled.
Use a s/driver and gently tap (downwards) at the divot points (shown in previous pics) and cast metal cap will then come away. Hahaha, now I did this as gently as I could, however, some of the plastic making up the rest of the mtr body came (broke) away with the metal cap. This is the dark material visible inside of the cap on the circumference. I may not have been consistent in applying force around the whole cap, I think....damn you stupidity, you always follow me. Should not be an issue as it will be assembled back as per original location.
A small dab of glue (high temp) should secure this area and hopefully shaft alignment will remain ok. I will use a high temp super glue to do this as I don't want any volatiles associated with the glue to cook off and seep past the new bearing seals.
There is a compression washer that sits on top of the front bearing (photo).
The cct brd has x3 solder points and some plastic welds holding it in. I will tackle these soon and document...hopefully this evening, got to hit the pool now for some laps.
5 Attachment(s)
Alrighty then...Removal of fan mtr pcb. I used a decent soldering iron that I normally use when I populate a pcb and subsequently solder components to the board. Mine has an adjustable heat setting that I cranked up reasonably high (photo).
We want to de solder those x3 solder points (photo showing black dots at points), as they are chunky points we need some high temps. This is needed to melt quickly and clean the solder, limits the amount of time applying heat (too much heat is destructive). I then used a pneumatic solder sucker to vac up the molten solder. Reasonably straightforward, if you have experience....potentially disastrous if you do not. The x2 plastic welds (photo black dots) can have their tops carefully broken away using flat blade jewellers s/driver. Then carefully pry up the pcb, access to remove the complete rotor is now available.
Photos show tools used etc and rotor out, showing bearings. Bearings seem rather "dry" with some axial/slop movement. I don't have a small enough bearing puller to get them off so have to have a think what to apply to remove them. There is a c/clip behind each bearing, best to remove these before bearing removal. Also be wary, rotor is very magnetic and will find any ferrous material lying around to suck-up. Yeah, like fine little bits that will stick to rotor. Just BTW, same place where my soldering iron (photo) was made is where the bearings were also made...so, there's ya problem. I will be back with bearings off, haha, hopefully...
5 Attachment(s)
OK, bearings have been removed.
I'm very aware that you guys/gals will know all of what I'm doing (or have done-as it is your profession). And my documenting, is only to show others, such as me, with limited knowledge, limited appropriate tools, limited $'s but good amount of time available, a way to go about repairing (hopefully-not there yet) an AC fan mtr (+other things along the way).
Big problem is/was I don't have mini gear/bearing pullers, I have pullers for auto use - too big. So had to improvise with what I had available.
Front bearing I used all that is in photo#06 (+piece of wood to tap mtr shaft). Clearance/distance from rotor to bearing is limited to fit tools into. Used an old bike multitool (#1) to slide under bearing (via gap in tool). Make sure to protect rotor - hence bubble wrap. Held the longer end of the m/tool and supported smaller end on the edge of my desk. Arrow on m/tool is where shaft + bearing supported. Applied some spray on lube to shaft, gave the mtr shaft some (non forceful) hits to move the bearing further up the shaft. This allowed tool #2 (auto ball joint splitter) to then be used. The piece of inner tube rubber used to cushion shaft end - to not burr or distort it.
Rear bearing as per photo#05. Same arrangement as front bearing, however could not fit #2 into clearance. So kept #1 under bearing supported via tool box corner (as needed more than two hands) and tapped on mtr shaft with tool #3 (brass plumbing valve extender).
All good, bearings off, no distorting of mtr shaft ends and no damage to rotor. Keep the b/wrap under the #1 tool to stop damage when tapping.
Keep in mind hard hits to magnetic items, IE the rotor, may disrupt their magnetic properties (heat will also affect as well), so go easy on the hits to shaft and no heating.
If I had appropriate brass drifts would have been better. Took < 8 minutes to remove bearings. Time to cook up a scheme on how to do it took the time...if one has mini pullers etc, would be easy as.
Just out of curiosity I weighed the old bearing(s) = 12 grms. I'll weigh the new bearing(s) and see what they come in at. Bearing specs; OD=22mm, ID=8mm, D=7mm. When I have new ones, will add more documentation. Photo#06 in following post...
1 Attachment(s)
Photo#06. Shows what I used to remove front bearing...Attachment 15842
I always maintained that our assistants should come with arms containing seven elbows if they wanted to be of any use at all.
Haha, that gave me a good chuckle Brian. Get a move on evolution....I've got things to juggle. OK, I have got the bearings. They are, an ubiquitous, # 608zz (Timken for me + many other brands available), easy to get and cost effective. I'm still waiting on the blower fan end bearing/bushing to rock up...a 2,700km journey from South Oz. We wait for many days/wks for goodies, I think in the UK, you get goodies in a matter of days....?
Hopefully will have a go putting new bearings on rotor shaft tomorrow. Thinking a 10mm deep socket (as inner race od ~ 10mm) + F clamp should do the trick(?), we'll see how it goes + will include some tips to allow the "motor drive" chip (on cct brd internal to motor) to have a more effective heat-sink.
Hahaha a joke with seven elbows, I appreciated, or it was not a joke ... In any case, I was reminded of this one funny story. I had an air conditioner since 2010, no one followed it. It so happened that I had to call the guys from airconservicingsingapore.com. One guy came to me, he was so pleased, called him to service the air conditioner. Everything would be fine, but my air conditioner is in a hard-to-reach place. Together with this guy, we somehow got him, but this poor fellow hit his elbow, apparently a nerve hit or something. He portrayed such a face, I suggested that he take a break and take a break, but with a smile he said it’s not worth it, although it was clear that he was in great pain. If possible, he would use foul language. Oh, he was a funny guy, of course, after the renovation, I offered him a cup of tea, and we got into conversation, as he worked the last day, that's why he came to me so happy.
2 Attachment(s)
Apologies to all...have been busy, and have not got to the bearing install + the blower end bearing has just rocked up today. Will give it a go tomorrow and can now assemble the motor + can install the motor + blower into the d/pain and get that section completed.
And, Brian_UK, CarolynVJ (do you bounce a lot?); don't forget, Chernobyl has not yet finished providing "gifts". So 7 elbows might be available in the near future....
Photos of internal motor circuit board shows chip with white on it. The white is a thermal conducting paste. The chip is involved in driving the inductance magnets (coils) in the stator. So we have v.fast current switching with respect to time (di/dt), therefore lots of energy = heat. Upper chip surface will be designed as a dissipation area and the paste thermally "connects" the IC to the mtr metal cap, which will act as a heat sink and release the heat to the outside.
However, I have noticed, that the paste on the top of this IC is now pretty much dried up (solidified). It should be a pliable paste to work effectively. This needs to be replaced. I will do this when assembling the mtr (& advise how to). Because at this point it's doing bugga all for the IC and chucking the heat back inside the mtr housing and will be the same in motors that have some age. Plus I have some (easy) info on testing these motors (+others), might be useful. I will post the link next post...
A good job takes time. Any 'coil rash' yet 🤣
