QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 07-12-2002, 12:59 AM
dar's Avatar
dar dar is offline
Registered User
Hey, I am new to : RE
dar is on a distinguished road
Snow Problems
relatively new installation research building that uses chiller that supplys chilled water to coils at 50*f with face and bypass steam system for heat. The problem Im experiencing is the plenum chamber seems to be to short and on heavy snow days the plenum accumulates lots of snow that saturates the filters and slings freezing water and trips the freeze stat any suggestions on how could remedy.
  #2
Old 07-12-2002, 01:13 PM
Andy's Avatar
Andy Andy is online now
Moderator
Site Moderator : and general nice guy
Andy is on a distinguished road
Hi,dar
I take it that the snow is comming in from outside? The chilled water is at too high a temp to freeze moisture from the air.
Regards. Andy.
Sponsored links
  #3
Old 08-12-2002, 04:58 AM
dar's Avatar
dar dar is offline
Registered User
snow problems
Yes Andy the snow is coming from outside theres a short space between the outside wall and the plenum chamber. about 3feet. after which the filters are located which are currently paper type 24"times24"by2" after the filters there is a heating coil which uses steam at 13psi which is a face and bypass type system a problem i beleive is the configuration of the steam coil only directs heat downstream of the coil and none of the heat radiates back towards the plenum chamber and as a result im getting piles of snow at filter supply side which being paper buckle and allow freezing water to reach freezestat tripping out unit.
  #4
Old 08-12-2002, 03:06 PM
frank's Avatar
frank frank is online now
Moderator
frank is on a distinguished road
The steam coil after the filters will be either pre-heat or heat and will offer no protection to the filters at all. Protection for the filters (and for the steam coil if it is off) should be handled by a frost coil or heater tape prior to the filter and should be controlled by a freeze stat set at +5C or thereabouts.
Without frost protection you are in danger of losing you steam coil if it is ever turned off.
Frank
  #5
Old 08-12-2002, 06:34 PM
Gary's Avatar
Gary Gary is online now
VIP Poster
Gary will become famous soon enough
If I understand correctly, we are talking about the fresh air intake going into a mixing chamber. I would suggest a hood on the outside.
__________________
Author of TECH Method troubleshooting books
  #6
Old 26-12-2002, 06:33 AM
twcpipes's Avatar
twcpipes twcpipes is offline
rookie poster
twcpipes is on a distinguished road
Questions:
1. What is the cfm entering the duct from outside?
2. What size is the duct?
Thanks, Tom
__________________
Tom D.
  #7
Old 17-01-2003, 02:06 AM
abcdefg1675's Avatar
abcdefg1675 abcdefg1675 is offline
regular poster
abcdefg1675 is on a distinguished road
Couldnt you use some sort of Anti-freeze in small amounts?
__________________
one mans trash is another mans treasure
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Suction pressure problems on TS units at low ambient temps nova Transport 10 18-03-2006 08:35 PM
Problems LG don't want you to know about Andy W Air Conditioning 11 16-02-2006 05:52 PM
Oil return problems Peter_1 Industrial 37 23-08-2004 11:30 PM
Snow Derek Technical Discussions 2 24-11-2002 02:32 AM
oil pressure problems on air dryer edge Trouble Shooting 1 16-07-2002 02:10 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
