QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 15-03-2001, 12:51 AM
Brian_UK Brian_UK is online now
Moderator
Site Moderator : and general nice guy
Brian_UK will become famous soon enoughBrian_UK will become famous soon enough
Question
Apologies for my lack of technical knowledge but this question arises from one asked on alt.hvac regarding the Danfoss 12/24volt compressors BD35 running on R134a.
These comps use capillary lines for off cycle equalization and the compressor can be speed changed in 500rpm steps from 2000rpm to 3500rpm.
My knowledge of speed/pressure square laws provide me with some thoughts on what might happen to the suction and discharge pressures but my understanding of the effects on refrigerants is incomplete.
If the machine is set up to provide a -15°C evaporating pressure at 2000rpm but we needed a quick pull down would the pressures changes cause much effect on the evaporator temperature or will the increased gas flow counteract these?
The scenario I am thinking about is using one of these comps for a vehicle based cold box which could be 'fast' cooled before use.
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
  #2
Old 15-03-2001, 12:54 AM
Moderator
Red face
Sorry just realised where I posted the above but couldn't quite see it as Commercial or Industrial Fridge.
__________________
Brian
Sponsored links
  #3
Old 20-03-2001, 10:36 PM
Moderator
Thanks Marc, I now have some more data/knowledge to digest, I'll just have to get the notepaper and pencil (plus calculator) on the go.
__________________
Brian
  #4
Old 21-03-2001, 12:37 AM
Dan's Avatar
Dan Dan is online now
Moderator
Dan is on a distinguished road
Hmmm. Thought I posted a replay way back when. I agree with Marc's thoughts. Although I disagree that suction "has to drop with higher speeds and the same evaporator."
Looking at it from a different perspective in hopes of addressing your question regarding "quick" pulldown, I have a comment or two. Of course, speeding up a compressor will dramatically increase the rate of pulldown in a high load situation. It won't necessarily lower the suction pressure to what you might consider design, however simply because of the high mass flow related to greatly increased refrigeration effect. But the pressure will be lower than if you didn't increase the speed of the compressor.
The inefficiencies of a speeded up compressor during pulldown are more than offset by the uncomfortable efficiency of a motor sluggishly trying to overcome a high suction pressure and hot space temperatures. Further, the increased efficiency of a compressor operating more slowly during low load conditions perhaps is what variable speed design focuses on as the greater good.
Think of it this way, lets say you controlled the speed of the compressor by attempting to maintain a certain suction pressure. The compressor would certainly find its entire speed range in use during the cycle between pulldown and satisfaction. And would most likely see the highest suction pressures when its top speed is insufficient for the hottest load that it sees. But basically you would be operating at a single suction pressure. Wonder how a condenser should be sized... methinks toward the high end of the load range. Maybe with a fan attached to a shaft from the compressor?
I am not clear if you are considering a cap tube system as the sole metering device. I would advise against it if you want a quick pull-down. But even still, some of the dynamics are in place. You will increase your head pressure which will tend to feed more refrigerant through the cap tube, but I don't see it working out to much advantage for quick pull downs. Although I can see it working okay for unloading purposes okay. Home fridge duty and that sort.
  #5
Old 15-05-2002, 06:07 AM
zolar1's Avatar
zolar1 zolar1 is offline
Senior Poster
zolar1 is on a distinguished road
Perhaps the variable speed compressor is designed so that system draws lower current on startup, then gets a fast pull down (temporarily), then stabilizes at the 2000rpm rating for the designed refrigeration effect.
Kind of like 'priming' the system with refrigerant for faster cooling.
Interesting theory though.
__________________
Zolar1, manager of http://afirsttimecomputeruser.Lefora.com/
MS Messenger ID = email addy : Zolar1@hotmail.com
I visit http://www.fuel-saver.org frequently & log my MPG with http://www.fueleconomy.gov
  #6
Old 18-05-2002, 11:37 PM
Moderator
Actually Zolar, these compressors are designed for caravan/boat/RV usage (amongst others) and you are correct in saying that the current draw is important.
It allows the OEM to set a maximum battery drain and sell that fridge that way.
__________________
Brian
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Help! fridge freezer probs Glenreed Trouble Shooting 2 06-01-2006 11:51 PM
Variable speed screw compressors Friobernal Industrial Compressors 1 14-11-2004 10:28 AM
Fridge compressor's can anyone explain why this happens....> electro Domestic 10 24-07-2002 02:30 PM
help- my bar fridge is wacko?! ben Trouble Shooting 3 25-01-2002 01:06 AM
is my fridge working properly? vincec Trouble Shooting 1 15-01-2002 10:55 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
