A minus 20 walk-in with a capillary tube? I have never seen nor heard of such a beast!
Self-contained reach-ins when empty can short cycle air, however. The top mount evaporators often have angled fans discharging air toward the front of the box and the air returns up the rear of the box. With no product in the box, the air short cycles because there is no wall of product to assist the discharge air to travel the vertical length of the box. The discharge bounces immediately back to the return of the coil.
Thus, you have an active cold area at the top of the box and virtually no refrigeration in the remainder of the box.
The thermostat satisfies, or the low pressure control satisfies before you can achieve gravitational advantage of the cold air in the lower portions of the box.
But walk-ins........ well I just have to think you meant reach-ins.
