If the unit is R134a then you should be able to pick up snap on adaptors from any good a/c distributor, HRP eg. If no luck with your local supplier try VACP, who I see have been taken over by four seasons.....anyway, try the VACP link at the bottom.
If it is an old R12 unit then perhaps you may need a high side adaptor but I don't remember them using that type of fitting.
Don't forget that BMW tend to hide the sightglass under the trim plate next to the firewall.
Have fun.
VACP
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
