QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 19-04-2002, 01:34 PM
pirestani's Avatar
pirestani pirestani is offline
improving poster
pirestani is on a distinguished road
Question centrifugal fan
Good time
Have you ever paid deep attention to the concept
of functional curve of centrifugal fans with thin ,
forward blades such typical one as "NICOTRA" ?
What happen when this blower works at the same
static pressure and different air flow rates on the
constant rpm ?
thanks s.pirs.
__________________
S.P
  #2
Old 23-05-2002, 05:39 PM
BritCit_Juve's Avatar
BritCit_Juve BritCit_Juve is offline
regular poster
BritCit_Juve is on a distinguished road
Because the static pressure and external are tightly related I don't think this situation could exsist. The fan is usually selected, along with its motor, belts and pulleys, to meet a set criteria of airflow against static. Lower the static on that match and the airflow will go up and vice versa.
As an example when a fan is selected to do an airvolume of x against an external static of y but is used against an external static of d the equation is
resultant airflow R=1/(square root(x*(d/y)squared))
x and R are m3/s whilest d and y are Pa
I hope this helps
BritCit_Juve
Sponsored links
  #3
Old 24-05-2002, 01:21 AM
Dan's Avatar
Dan Dan is online now
Moderator
Site Moderator : and general nice guy
Dan is on a distinguished road
I agree, I didn't realize that one could maintain the same static (Total static pressure) and change flow rates without resizing the devices that are in the air stream. I am not sure I understand the question.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
York Centrifugal Peter_1 Industrial Compressors 12 14-08-2005 01:25 PM
backforward curve centrifugal fan Lc_shi Fundamentals 1 29-04-2005 10:35 PM
selection of centrifugal fan watana Air Conditioning 0 14-09-2003 04:02 AM
Centrifugal chillers part 2 reggie Industrial Compressors 0 16-05-2002 09:07 AM
Centrifugal chillers reggie Industrial Compressors 2 02-05-2002 07:22 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
