QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 07-04-2002, 10:52 PM
Stuart's Avatar
Stuart Stuart is offline
regular poster
Stuart is on a distinguished road
Unhappy a/c seer
Can anyone tell mr what A/C SEER is & how it affects the system?? would be grateful for the advice. Thanks in advance.
stuart.
  #2
Old 08-04-2002, 03:15 AM
Prof Sporlan's Avatar
Prof Sporlan Prof Sporlan is offline
Moderator
Prof Sporlan is on a distinguished road
SEER (Seasonal Energy Efficiency Ratio) is an efficiency rating for unitary a/c system under 65,000 Btu/hr. It is the cooling capacity of the unit in Btu/hr divided by the energy comsumption in watts. The standard can be downloaded from here.
In short, there are 4 separate tests performed to simulate normal usage of an a/c units:
'A' test is at 95°F ambient, 80°F DB/67°F WB return air temperature
'B' test is at 82°F ambient, 80°F DB/67°F WB return air temperature
'C' test is at 82°F ambient, 80°F DB/57°F WB return air temperature
'D' test is a cyclic test at the same conditions as the 'C' test.
The actual calculations necessary to determine the SEER rating are a bit involved, but specified in the above Standard.
__________________
[b]Prof Sporlan[/b]
Sponsored links
  #3
Old 11-04-2002, 07:42 PM
Stuart's Avatar
regular poster
Wow thats very involved. Is it necessary to work out the seer in all cases or is it provided by the factory.
Is seer needed on all visits to service all refrigeration systems?
__________________
:cool: [COLOR=Red]Do the job once & do it right.[/COLOR] :cool:
  #4
Old 12-04-2002, 12:47 AM
Moderator
SEER is determined by the equipment manufacturer and subject to independent verification. All a service technician would need to know is that it is a rating standard. 10 SEER is the current minimum mandated by the DOE, 12 or 13 SEER will be the new minimum by 2006, and for example, a 12 SEER units is approx 20 percent more efficient than a 10; 13 SEER is approx 30 percent more efficient than a 10.....
__________________
[b]Prof Sporlan[/b]
  #5
Old 12-04-2002, 02:47 PM
herefishy's Avatar
herefishy herefishy is offline
VIP Poster
herefishy is on a distinguished road
Unfortunately, high SEER ratings are responsible for the destruction of real property. Here in Texas, there is a growing number of mold damage claims due to humid enviroments in occupied spaces, in addition to just water leakage within a (home).
Now I profess myself NOT to be an A/C guy, but my understanding is that higher SEER ratings are acheived through different means, but in direct discussions with very knowledgeable people, I understand the net result to be a system which does not efficiently address latent load (humidity).
Most of Texas is technically a sub-tropical climate, so it has become a big issue. As a matter of fact, it is becoming difficult to obtain general liability insurance as a mechanical contractor in this state because of the mold issue.
  #6
Old 12-04-2002, 04:06 PM
herefishy's Avatar
VIP Poster
All of the energy in the universe is constant. We know what the "energy" of heat transmission and latent (load) is.
All SEER is, is a standard which measures the amount of work which is NOT being done!
  #7
Old 12-04-2002, 06:50 PM
Moderator
One means by which SEER rating can be increased is raising the evaporator temperature, which is generally not a problem for Phoenix, but could well present indoor humidity problems in Houston.
That is why having a good a/c technician select and install the unit will be more important for the average homeowner than the SEER rating of the unit.
__________________
[b]Prof Sporlan[/b]
  #8
Old 12-04-2002, 11:47 PM
Gary's Avatar
Gary Gary is online now
VIP Poster
Gary will become famous soon enough
I would think every tech in Texas should know to slow the blower down.
__________________
Author of TECH Method troubleshooting books
Sponsored links
  #9
Old 13-04-2002, 12:02 AM
Dan's Avatar
Dan Dan is online now
Moderator
Site Moderator : and general nice guy
Dan is on a distinguished road
LOL. Same goes for techs in Florida. Big condensers: Good. Big evaporators: Bad.
  #10
Old 13-04-2002, 12:20 AM
Gary's Avatar
VIP Poster
Actually, big evaps can take an even lower airflow before the coil freezes, with a lower ADP, thus more humidity removal than a smaller evap.
But a big evap with high airflow is bad news in a humid area.
__________________
  #11
Old 13-04-2002, 01:17 AM
herefishy's Avatar
VIP Poster
You're exactly right!!!!!!!!.... And that just BLOWS the whole SEER bullsh*t out of the water, doesn't it?
This SEER thing is just a political scam.... like cigarettes.
  #12
Old 13-04-2002, 01:41 AM
Gary's Avatar
VIP Poster
LOL
Well...not a total scam. The evap/airflow balance is a tradeoff: Efficiency versus dehumidification. You still get the increased efficiency of the larger condenser, and scrolls are more efficient.
And in dry areas, they can crank up the airflow until the compressor gets a hernia.
Don't get me started on the TobaccoNazis...Grrrrrrrrrr...
__________________
Sponsored links
  #13
Old 23-05-2002, 08:57 PM
superheat's Avatar
superheat superheat is offline
regular poster
superheat is on a distinguished road
SEER is a big rip. Government says you can't build equipment with less than say 12 SEER. YOU CAN'T BUILD A 12 SEER SYSTEM UNLESS IT IS A PACKAGE SYSTEM. It is a system with several parts. A 3 ton 12 seer CU with a 2 ton evap can be installed legally, but it will not be 12 SEER. Now let's talk about leaky undersized ducts. How about never changing the filter. It is just something that some lawyer/congressman developed to solve all the world's energy problems.
  #14
Old 23-05-2002, 09:40 PM
Gary's Avatar
VIP Poster
People don't seem to understand that a system has four major sub-sections. Condensing unit, evaporating unit, piping, and ductwork. Any of these can make or break the system.
__________________
  #15
Old 24-05-2002, 02:12 AM
Moderator
Time and effort spent on developing proper training and certification programs, and educating the homeowner on the benefits of having qualified personnel install and service residential hvac equipment, will prove to be better policy than some arbitrary increase in minimum SEER ratings...
__________________
[b]Prof Sporlan[/b]
  #16
Old 07-01-2007, 01:58 AM
momo's Avatar
momo momo is offline
regular poster
momo is on a distinguished road
Re: a/c seer
Trying to find out about SEER (USA) and EER (Europe) and how they compare I came across EER=SEER/3.5 approx. Correct?
Does this explain why Europe (Spain) is now plagued by low price low efficiency i.e. EER 2.6 R407 A/Cs made in P.*.C. - because the USA will not buy them, especially wall splits!
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Why no more 10 seer goodman? cooljesus Air Conditioning 10 02-09-2006 01:37 AM
The Road To 13 SEER WebRam Refrigeration Articles 6 12-07-2004 09:53 PM
Capillary Tubes subzero*psia Domestic 19 26-06-2001 11:56 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
