QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 02-12-2001, 06:47 AM
aaron crimmins's Avatar
aaron crimmins aaron crimmins is offline
improving poster
aaron crimmins is on a distinguished road
Angry cleaning trane cond.
anybody know of a good way to clean the condensers on the new trane units that have those "fuzzy" fins. besides pouring lighter fluid on them and burning them off! we use chemical cleaner and a pressure washer to clean everthing else but it folds over those "fuzzy" fins and packs them together. any other ideas?
  #2
Old 04-12-2001, 11:48 PM
Brian_UK Brian_UK is online now
Moderator
Site Moderator : and general nice guy
Brian_UK has a spectacular aura aboutBrian_UK has a spectacular aura aboutBrian_UK has a spectacular aura about
Re: cleaning trane cond.
Originally posted by aaron crimmins
We use chemical cleaner and a pressure washer to clean everthing else but it folds over those "fuzzy" fins and packs them together. any other ideas?
I'm not familar with the exact coils that you are talking about but I think I have seen something similar.
How about using the clemical cleaner in a LOW pressure sprayer instead of the HIGH pressure washer.
Or could you stand about 100 feet away from the coil when using the high pressure one.
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
You should always give 100% at work...
12% Monday; 23% Tuesday; 40% Wednesday; 20% Thursday; 5% Friday
Sponsored links
  #3
Old 05-12-2001, 06:57 AM
frank's Avatar
frank frank is online now
Moderator
frank will become famous soon enough
Post
we use a foaming chemical cleaner such as "hydrocoil" whis is applied diluted - strength according to level of contamination - with a low pressure spray. Once the stuff has finished foaming and removing the dirt we just give the condenser a rinse with clean water, again using a low pressure spray and the job is done!
  #4
Old 05-12-2001, 07:00 AM
wolfdog's Avatar
wolfdog wolfdog is offline
Registered User
Hey, I am new to : RE
wolfdog is on a distinguished road
When they are real dirty, I usually have more success blowing water from the inside of the coil towards the outside. Pull a condenser fan out and reach inside with a spray nozzle on a water hose. Worst case -- wash them out as described and then use chemical. Then hope they keep them cleaner from now on.
  #5
Old 09-12-2001, 05:05 PM
improving poster
thanks for the info. guys i talked to trane and they tell me that these new fins are designed to run a lower head when they get dirty comparied to the common fins out there. i think i'll try and keep them clean though!
  #6
Old 11-12-2001, 08:52 PM
frank's Avatar
Moderator
How does that work then - a lower head when the coil is dirty?
Seems like a really good invention!
  #7
Old 23-05-2002, 09:34 PM
superheat's Avatar
superheat superheat is offline
regular poster
superheat is on a distinguished road
I have a nozzle that has several different stream ports. It is on a 4' tube with a cut-off near the hose attatchment. You clean from the inside-out without killing your back. No bending over and you can still watch the water come out. Spray till the water comes out clean. Chemical cleaners are overrated in my book.
  #8
Old 10-06-2002, 11:20 AM
hvac01453's Avatar
hvac01453 hvac01453 is offline
improving poster
hvac01453 is on a distinguished road
The fins are called spine fin and have been around for years. They tend to trap pollen alot more than the straight type fin but do disipate heat over a larger area and therefore use less aluminum (cheaper). they clean easily with Nubrite foaming cleanser we usually cut it 50/50 and spray from the inside out and it comes out easily. also tell the customer when they cut the grass to temporaily shut off the units and they will stay cleaner longer.
__________________
My wife says I don't listen to her....or something like that....
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Trane RTAD125 Problems Latte Trouble Shooting 10 10-05-2010 11:38 AM
Are Trane Expensive frank Air Conditioning 17 20-05-2009 01:55 PM
Trane HP Defrost Board Problem FastEd Heat Pumps 8 05-09-2008 01:30 AM
Trane CGCE207 Problems AWCarillion Trouble Shooting 2 09-08-2005 08:58 AM
Trane Filters Abe Commercial 7 30-09-2004 08:40 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
