QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > TECHNICAL REFRIGERATION > Fundamentals
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 19-04-2006, 01:12 PM
vijay_study's Avatar
vijay_study vijay_study is offline
regular poster
vijay_study is on a distinguished road
Cold Room Design - minus 25deg C
Dear All,
I am designing a cold room having following key features:
1. Inside Temperature = minus 25deg C
2. Complete area is Flameproof.
Are their any websites / articles available which can guide regarding the basis of cold room designs.
Please comment.
Vijay Kumar
__________________
Vijay Kumar
HVAC Design Engineer
BMCPL
"The more you sweat in peace less you bleed in war"
  #2
Old 27-04-2006, 09:41 PM
Peter_1's Avatar
Peter_1 Peter_1 is online now
Moderator
Site Moderator : and general nice guy
Peter_1 will become famous soon enough
Re: Cold Room Design - minus 25deg C
Dossats, an in fact every descent Refr. book
__________________
Sponsored links
  #3
Old 27-04-2006, 10:42 PM
Alex Harvey's Avatar
Alex Harvey Alex Harvey is offline
improving poster
Alex Harvey is on a distinguished road
Here are a couple to start off with. Try http://www.rackettering.com click on cold store, http://www.cold-store-room.com or http://www.walk-in-freezer.com.
Depending on the size of the room you will need a heater mat in the floor. The wall and ceiling panels can not be made of polystyrene insulation. The lights will need to be fireproof. Keep all wiring external to the coldroom box.
Use the above websites as a start for a wide search on google etc.
  #4
Old 28-04-2006, 06:29 AM
Peter_1's Avatar
Moderator
This seems advertisement for me and I suggest you talk to Webram for a paid add at the right side of this forum.
__________________
  #5
Old 12-02-2008, 02:15 AM
Magoo's Avatar
Magoo Magoo is offline
VIP Poster
Magoo is on a distinguished road
Stay in your comfort zone with HVAC and contract Refrigeration to a proven refrig company.
magoo
  #6
Old 12-02-2008, 08:10 AM
smpsmp45's Avatar
smpsmp45 smpsmp45 is offline
VIP Poster
smpsmp45 is on a distinguished road
One has to even check out the heaters on the door drame. Yu do get special heaters for the doors which are flamr proof category.
We had done a similar project for various chemical industries like Finolex / Peroxides India etc.
We were using central plant in few cases & the fan motor, door heaters, were flameproof type. The Solenoid valve on the evaporator was just outside the cold store area. The panels were made in such a way that the roof panel to wall panel joint was the weakest joint so that in case of explosion, the Ceiling goes off. ( It never happened in 15 years though). The plant room was almost 16 mt away & there was a huge wall between the plant room & the Cold store area. We had also fitted Smoke detectors in the cold store. They too were flameproof type. The defrost can not be hot gas defrost type.
Let me know if you need any other details
  #7
Old 12-02-2008, 08:54 AM
Samarjit Sen's Avatar
Samarjit Sen Samarjit Sen is offline
VIP Poster
Samarjit Sen is on a distinguished road
Hello Vijay,
Could you please let me know as to what exactly you are looking for. Do you require the design or want to know as the fire proof. Now fire proof panels are available. More over there are some safety precautions which smpsmp45 has stated.
  #8
Old 12-02-2008, 09:57 AM
jahangir.ahmad's Avatar
jahangir.ahmad jahangir.ahmad is offline
regular poster
jahangir.ahmad is on a distinguished road
Dear Vijay Kumar,
here is lots of fators u have never define
here i sa lot sof factors
  1. whats area of room ?
  2. whats the ambiant temp of ur city ?
like this
please purchease a book ""AIR CONDITIONING PRINCIPLES AND SYSTEM ""
FOURTH EDITION
AUTHOR
EDWARD G.PITA
AND ITS CHAPTER NO 06
NOW READ THIS BOOK U R ABLE TO MAKE A ROOM AS U REQUIRED
THANKS
JAHANGIR AHMAD KHAN
LAHORE PAKISTAN
Sponsored links
  #9
Old 13-02-2008, 03:57 PM
improving poster
When considering a cold store at minus 25deg C you should either have an air lock or at the least have a plastic PVC strip curtain accross the door to reduce the inflow of warm humid air intow the freezer room and reduce outflow of the cold air from the room.
Any ingress of humid air into the freezer will cause the moisture / water to freeze on the ceilings, walls and floorl causing a danger of slipping or ice falling from the ceiling in the worst case. This is in addition to the water freezing on the evaporator coil which will need clearing using a defrost heater.
Plastic strip curtains can be purchased in your local market for a few hundred US Dollars, but you need to specify 'Polar Grade'. There are a good number of websites I found on google. This is one quoting prices and specifications which might help.
pvc-strip-curtain-warehouse-plastic.co.uk
But there are plenty of others probabley more local for you.
  #10
Old 13-02-2008, 11:22 PM
Josip's Avatar
Josip Josip is offline
Moderator
Josip is on a distinguished road
Hi, all
Post of Vijay Kumar is from April 2006...I do believe till today he solved all his nightmares.....not sure, but I believe that was an Allana project
Best regards, Josip
__________________
  #11
Old 14-02-2008, 05:51 AM
smpsmp45's Avatar
VIP Poster
No. Surely Not Allana Project!!!!!!
They Do Not Deal In Explosives!!!!!!
  #12
Old 14-02-2008, 03:44 PM
improving poster
Hope the project went well. Please advise any time.
Sponsored links
  #13
Old 15-02-2008, 12:00 AM
Josip's Avatar
Moderator
Hi, smpsmp45
Explosives
......"flameproof" for me has a meaning panels are self extinguish and not explosion proof (Ex).....sorry, seems my english is not so good...
Then for sure you know which one was/is
Best regards, Josip
__________________
  #14
Old 15-02-2008, 04:05 PM
improving poster
Josip, correct. In the UK the composite insulated wall panels must be in PIR and have a fire rating. Expanded Polystyrene panels do not get an insurance rating as there were a number of cold store fires around 2001 with some loss of life.
  #15
Old 16-02-2008, 06:53 PM
maltysoft's Avatar
maltysoft maltysoft is offline
Registered User
Hey, I am new to : RE
maltysoft is on a distinguished road
very very thanks
very very thanks
very very thanks
very very thanks
  #16
Old 16-02-2008, 06:55 PM
nike123's Avatar
nike123 nike123 is online now
VIP Poster
I am starting to push the Mods: of RE
nike123 will become famous soon enoughnike123 will become famous soon enough
I think that you need to fix that keypad!
__________________
This is signature folks!
There's no such thing as a dumb question..............
But they are the easiest to answer.
Quis? Quid? Ubi? Quibus auxiliis? Cur? Quomodo? Quando?
Si tacuisses,philosophus mansisses.
Sponsored links
  #17
Old 17-02-2008, 10:06 AM
Kawaljeet Singh's Avatar
Kawaljeet Singh Kawaljeet Singh is offline
Registered User
Kawaljeet Singh is on a distinguished road
Dear friends Allana is competant enough to design and install complete freezing complexes, so far their own 15 such units of more that 150 mt per day freezing(-40 degreeC)capacity are working excellently well.
  #18
Old 18-02-2008, 04:14 PM
improving poster
Smile Re: Cold Room Design - minus 25deg C
munus 40 deg C, very low temperature for long term storage or Ice Cream!
  #19
Old 18-02-2008, 07:53 PM
VIP Poster
Allana has a number of Freezing facility all over the country, and just for information my dear freind Josip has been some how been associated with some of their projects. So I think he is fully aware of what he is talking.
  #20
Old 11-11-2008, 10:43 AM
ice_cool's Avatar
ice_cool ice_cool is offline
rookie poster
ice_cool is on a distinguished road
A few pages you can read for reference:
URL Removed
Hope the information is helpful to you.
Last edited by Peter_1; 03-05-2009 at 01:11 PM.. Reason: Commercial without prior permission
  #21
Old 11-11-2008, 12:26 PM
icecube51's Avatar
icecube51 icecube51 is offline
VIP Poster
icecube51 is on a distinguished road
this dossent smel,but stinks severe at COMMERCIAL
  #22
Old 11-11-2008, 12:48 PM
Peter_1's Avatar
Moderator
Ice_cool, Icecube51 has a point, this is a little bit on the edge of the allowable.
I suggest you edit your post and make only one link.
__________________
  #23
Old 21-12-2008, 06:54 PM
dyar's Avatar
dyar dyar is offline
Registered User
dyar is on a distinguished road
I AM ENGINEER IN REFRIGERATION AND AIR CONDITIONING ICAN AID EVERYONE MY EMAIL dyarmohammed @yahoo.com
  #24
Old 03-05-2009, 01:05 PM
Susanthaj's Avatar
Susanthaj Susanthaj is offline
Registered User
Susanthaj is on a distinguished road
Question Re: Cold Room Design - minus 25deg C
Hi.
I have to design a freezer cold room to maintain a temperature of -24ºC. What will the capacity I should use an the Unit.The space size is i44 cu Mts
Thanks.
Susantha Jayawardene
Resident Engineer.
InterContinental Hotel.
Doha,
Qatar
Sponsored links
  #25
Old 03-05-2009, 01:12 PM
Peter_1's Avatar
Moderator
Between 2TR and 200 TR
__________________
  #26
Old 10-05-2009, 06:11 PM
icecube51's Avatar
VIP Poster
before you start designing, start learning the basics of refrigeration and whit some luck,it all becomes clear and more easy.
Ice
  #27
Old 11-05-2009, 01:01 PM
improving poster
I'm sure this thread is now finished?
  #28
Old 12-05-2009, 12:44 AM
750 Valve's Avatar
750 Valve 750 Valve is online now
VIP Poster
750 Valve is on a distinguished road
Originally Posted by Susanthaj View Post
Hi.
Thanks.
Resident Engineer.
Doha,
Qatar
11.7 watts
In all seriousness would you trust a response someone gave you on the internet? If so you are in serious trouble buddy, pay a consultant to work it out for you or pass on the job and let someone who knows how to design the system do it properly.
__________________
...and she said "give it to me you big fridgie"
  #29
Old 12-05-2009, 06:18 AM
Peter_1's Avatar
Moderator
750 Valve,
I think this will be a little too small, I should take 13.8 Watts and eventually divided over 2 compressors for security
__________________
  #30
Old 12-05-2009, 07:58 AM
750 Valve's Avatar
VIP Poster
Originally Posted by Peter_1 View Post
750 Valve,
I like the way you think Peter - partial redundancy in your suggestion
__________________
  #31
Old 12-05-2009, 07:29 PM
cool&heat's Avatar
cool&heat cool&heat is offline
Registered User
cool&heat is on a distinguished road
Hi.
Thanks.
Resident Engineer.
Doha,
Qatar
In Qatar you can contact the unites suppliers in business directory they will help you free.
  #32
Old 19-05-2009, 07:21 AM
Sridhar1312's Avatar
Sridhar1312 Sridhar1312 is offline
regular poster
Sridhar1312 is on a distinguished road
I had designed a cold room of minus 25 degree C with explosion proof concrete walls and collapsible Tin sheet roof with insulation.
This was for a vinyl monomer caltalyst storage used in PVC Manufacturing.
We had done with Brine chilling plants with cold diffuser units in the cold room to maintain minus 25 degree C.
need more details please send email to <enervac.sv@gmail.com>
Sponsored links
  #33
Old 06-11-2009, 03:49 PM
sasikumar5's Avatar
sasikumar5 sasikumar5 is offline
Registered User
sasikumar5 is on a distinguished road
Please give your details in my mail id sasi@indiametalworks.com
  #34
Old 10-11-2009, 09:06 PM
gesi's Avatar
gesi gesi is offline
improving poster
gesi is on a distinguished road
Ice
Hi icecube51. How are you? my proposal for our friends is programme scelte32 from ECOgroup. learning, designing in the same time. of course if they have free time.
good luck for all.
  #35
Old 11-11-2009, 08:12 AM
regular poster
The cold room you are looking must be for Catalyst to be stored at minus 15 to 20 degree C.
Way back in 1882-83 have executed a project for minus 25 degree Cold room with massive 10 inch concrete walls and roofing out of corrugated GI sheet with relief door to open when the pressure increases due to warm up and beyond which roof will collapse.
You may send your specific queries as private message and will be in aposition to help you.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Cold storage - Onions room Kevin Yeo Fundamentals 31 14-02-2008 04:42 PM
Cold Room Design vijay_study Fundamentals 11 09-07-2007 08:11 AM
Cheese Room Design 24V DC jbelding Fundamentals 10 02-04-2006 03:23 PM
Installation of cold room Josip Legal-Business-Marketing 12 12-03-2006 10:20 PM
Large cold room for fresh produce made of Glass allanbaker New Technologies 3 11-05-2004 09:04 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
