Hi Jai and welcome
I'm not a great lover of inverter units but the incoming 110vac single phase (I normally deal with 240v but...) is used to charge up some capacitors. The dc power from the capacitors is then fed through transistors (big ones) to create three phase ac voltage to feed the compressor motor.
I will try and find some more info for you and come back.
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
