Originally posted by eberg
I have always made sure that the last task performed (just prior to evacuation) during a/c service is to remove the drier port plugs and make the last 2 hose connections to minimize the amount of exposure time to atmospheric moisture.
Welcome eberg, your proposed installation method of the filter/drier is spot on
I don't know the exact time that a filter takes to absorb moisture but the actions taken by your parts-man are effectively killing the drier.
ALL manufacturers of moisture absorbing products such as oil and driers insist that they are the last thing opened and fitted. The new POE oils especially will suck up moisture like it's going out of business.
Tell you parts supplier that any seals broken on any boxes or products will be counter charged with interest and I would suggest that you tell his supervisor also.
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
