QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 06-08-2001, 09:21 PM
Brian_UK Brian_UK is online now
Moderator
Site Moderator : and general nice guy
Brian_UK will become famous soon enoughBrian_UK will become famous soon enough
Question Correct Title For this Sub-Section?
I keep looking at this sub-section and no-one, including myself, seems to have come up with a request for anything tecthnical .
It is making me wonder whether in fact there is anything technical about A/C or are we all too clever for our own good?
Most of the potential problems have propably already been discussed elsewhere under TEVs or cap tubes and of course filter/driers.
I suppose the tricky bits are the electronics and as most people just replace a faulty part you can't really call changing wires and plugs technical can you?
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
  #2
Old 11-12-2001, 10:12 PM
BritCit_Juve's Avatar
BritCit_Juve BritCit_Juve is offline
regular poster
BritCit_Juve is on a distinguished road
I just thought you might be getting lonely in here. Changing wires isn't technical thats why there are so many electricians about.
Problem with this area is that most questions you would post here you would go to the manufacturer for. Maybe you needto change iit to Obscure technical to a/c or somesuch.
Sponsored links
  #3
Old 13-12-2001, 12:52 AM
Moderator
Whoa there BCJ, you'll be upsetting the natives
Mind you, I caught myself out the other day by listening to the account of an ac fault and not checking it completely myself.
A unit had been installed (2nd hand from client) and worked fine, then it had to be moved after which it didn't work. The report said that it HAD worked in the new position but didn't now.
Following what service info I had the fault appeared to be in the outdoor control board. Due to the age of the unit I recommended that the indoor board was replaced as well. So I replaced the outdoor board, same fault code shown but different signal voltages from the last test. So maybe something was going right.
Anyway, swapped the indoor board and still the damn thing wouldn't work
Rechecked all the cabling again and found that the installer had wired in a condensate pump putting the neutral into the interconnecting signal wire. So that's were my volts dissappeared too.
Problem solved, unit working, crept away very quietly
__________________
Brian
  #4
Old 13-12-2001, 04:43 AM
Mike Hopkins's Avatar
Mike Hopkins Mike Hopkins is offline
regular poster
Mike Hopkins is on a distinguished road
Well maybe this would be the area to post on some of the many electronic or maybe control problems that are frequently encountered in AC/ Fridge work. I have heard stated that 90%
of service related problems are electrical / electronic. Somehow
that has not computed into fact for me but then I haven't done a technical study on it, just going by gut feeling of what I have had to deal with. But I do have some AC related electric/electronic nitemares to share.
Mike Hopkins
  #5
Old 13-12-2001, 09:41 PM
frank's Avatar
frank frank is online now
Moderator
frank is on a distinguished road
Thumbs up
Lets hear them Mike - you start the ball rolling and we will all join in
  #6
Old 14-12-2001, 01:15 AM
regular poster
Uh Oh! Now I'll have to think back a little and come up with some good ones for you. One common problem I have seen is where you get a call with the machine down on so and so fault. Arrive and find that the fault cannot exist for the condition operator is describing. At least in your mind it can't. But never say never.
On these newer machines and somewhat the older ones with micro processor controlled functions I have seen little shorts where the voltage was drawn down causing the micro to fault on
whatever it could come up with and the real problem be something else. Like wet connections on sensor plugs or flow switch connections wet from condensation. I did have a machine recently that was showing a fault on the to process sensor.
Micro looks at value and compares to known values, if not within
parameters, indicates fault. Well the plug connections to the sensor happened to be under suction side of 25 HP Copeland compressor doing 1*C leaving brine temp. and she sweated a bit and soaked the connector causing shorted sensor. A little contact spray and some ziplock bags and wire ties and were off and chilling again. That was easy one, unlike troubles mentioned above. I'll go and have a look see at the old service log and see what we can come up with.
Mike Hopkins
  #7
Old 14-12-2001, 06:45 PM
regular poster
The unfortunate thing is that the manufacturers keep their tips and tricks secret. They give some information in the manuals which you just cant get hold of and none on the unit.
At least they are starting to get the message these days though, still if they give us all the info I suppose they will start to feel they can charge a £1/min for the privalege.
Still they could at least make the wiring diagrams legible, there's nothing worse than trying to decipher the wiring on a unit you've never seen before especially when you need a magnifying glass to see it.
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
