Update.... well, I can't use the 6x24 duct on each side... I looked in manual D that answered that question. Now above my 4 ton A-coil (yes... 4 ton... old victorian home... huge) I had very little room for a standard plenum with transitional take-offs because this furnace is in the original mechanical or rather boiler room, which was built to be fire / explosion limiting by its construction. Anyway, I placed an 8x18 metal duct on top of my cased coil and cut out the front to take-off with an 8x16 duct run also. Now I have two 8x18's and one 8x16 trunk lines. Remember this house is old... fire-stops in the walls all sorts of things. To get ductwork upstairs (never had it before) I had to run a 12 inch flex off the bottom of one of the 8x18 trunks etc. (this is why I have the third trunk which is 8x16... to balance my system again.) Off the 12 inch I am installing a 24x24x48 inch fibre board duct and making five 6 inch duct runs and one 4 inch duct run. That will get me roughly 600 cfm upstairs, and I have 1200 cfm down. I haven't fired anything up yet... still have things to do but thought I would keep you posted... I am a refrigeration guy, always took air conditioning guys lightly.... I have to admit you boys deserve alot of credit and I hope you will give me a shout if you see something I need to know.
I know this much... I would rather do new construction for this type of work anyday.... sheesh what a hassle getting ductwork in this house and keeping the basement where it doesn't look shoddy. I have a finished basement which is liveable so installing ductwork is creating limitations on what and how I can accomplish this work... but I am sure that is nothing new to you all. Wish me luck. Maybe when I am done... I will take a picture and post the outcome... I said maybe....
