Daikin split help
Attended a site this morning briefly and found a 410a split system (rr100b8v3b) and found it with an e0 fault. Re-set the system. When the system starts up, condenser fans starts and then when it pulls the contactor in for the comp to start, the contactor gets thrown straight back out. The compressor does not even vibrate etc. The suction guage does not budge at all when the compe attempts to cut in. Once this happens, the fan cuts out straight away hpwever it does not go into fault.
I was expecting perhaps for the comp to trip the breaker but nothing. The e0 fault has not cut in since either. Just seems that the comp will refuse to run.
Any detailed checks or advice that anyone can give me for this.
Many thanks in advance.
