QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 31-01-2010, 02:23 PM
aquasanj's Avatar
aquasanj aquasanj is offline
rookie poster
aquasanj is on a distinguished road
Fixed orifice air conditioner not cooling down
Hi Super techs,
Recently replaced a maneurop compressor for a 19 Kw ducted split aircon because the exisiting comp had failed mechanically. Problem is that it does not pull down room temp.
Used Nitrogen while soldering the drier and pressure testing. Vaccummed the system and recharged as per manfrs specs based on piping lengths. (7.1 kgs)
(Had also weighed the charge when recovering which matched manfrs specs)
I have the following readings:Ambient temp 33*C/Room temp 26*C
Refrigerant R22
Low side 68 psi
Sat Suction t. 4*C
Suction line t. 23*C
Liq Line 230 psi (discharge 240 psi)
Sat Liq t. 44*C
Liq Line t. 41*C
Indoor unit air on: 26.5*C
Indoor unit air off: 18*C
Outdoor unit air on; 33*C
Outdoor unit air off: 41.4*C
condensor,evaporater and filters are clean
The suction pressure fluctuates between 60 and 75 psi approx every 30-40 seconds, and the orifice in the indoor unit makes a rattling sound during this period.
please help me figure out what is going on here. i know the super heat and sub cooling are out of order . From my knowledge i should expect 9k superheat and 8.5k subcooling. Pls correct me if i'm wrong guys...
Could the "accutrol" ( orifice rattling be the fault???)
cheers
  #2
Old 31-01-2010, 07:25 PM
troymedhurst's Avatar
troymedhurst troymedhurst is offline
improving poster
troymedhurst is on a distinguished road
Re: Fixed orifice air conditioner not cooling down
Originally Posted by aquasanj View Post
Hi Super techs,
Refrigerant R22
Low side 68 psi
Sat Suction t. 4*C
Sat Liq t. 44*C
Liq Line t. 41*C
cheers
Hi aquasanj,
just a couple of questions;
Did you re-use refrigerant?
Is there a small in-line filter before the fixed orifice? Could there be a foriegn object there? I had a similar expierience.
What type of control fan control do you have?
Looking at the temp/pressures you have, it is looking short of gas.
Could the noise be just a shortage of gas going through the orifice?
Sponsored links
  #3
Old 31-01-2010, 08:57 PM
mad fridgie's Avatar
mad fridgie mad fridgie is online now
VIP Poster
mad fridgie will become famous soon enoughmad fridgie will become famous soon enough
Sounds like a Temperzone to me.
Add a fraction more refrigerant.
You are getting flash gas through the orifice.
  #4
Old 31-01-2010, 11:42 PM
aquasanj's Avatar
rookie poster
Hi buddy,
I charged virgin gas, as for the filter, i can,t tell maybe it is inside the line just before the orifice and the orifice is soldered so i may have to disconnect to check.
The indoor fan is controlled by a wall controller and has 3 speeds. the outdoor fans (2) are fixed speed.
I managed to note down the info i gave when it was sitting at those pressures for a short while during its fluctuating cycles.
It may be short of gas but the liquid line is quite warm (41*C), i did think it may be short of gas but was reluctant to add more than the mnfrs specs....did not want to over heat the liquid line
cheers
  #5
Old 31-01-2010, 11:46 PM
aquasanj's Avatar
rookie poster
Hi mate,
Its an APAC unit, you probably heard of these.
I could add more gas but what would happen if my liquid line heats up too much......why would the suction pressure hunt as it does between 60 and 75 psi...not much change in the head pressure though....
cheers
  #6
Old 31-01-2010, 11:58 PM
Gary's Avatar
Gary Gary is online now
VIP Poster
Gary will become famous soon enough
Hi buddy,
cheers
Adding more refrigerant will cool, not heat, the liquid line.
Add refrigerant until the superheat is right.
__________________
Author of TECH Method troubleshooting books
  #7
Old 01-02-2010, 12:06 AM
VIP Poster
Hi mate,
cheers
Simply you are loosing your liquid seal at the orifice,
some times liquid, then sometimes liquid and vapour.
Add a little more refrigerant.
  #8
Old 01-02-2010, 03:28 AM
desA's Avatar
desA desA is offline
VIP Poster
desA will become famous soon enough
With an effective SC ~ 0K for an air-cooled condenser, would you expect to be able to achieve a full liquid seal at condenser outlet?
I wonder if perhaps the OP could have positioned the new filter-drier slightly differently to the previous one? Is it set in the correct flow direction?
__________________
High-temperature, high-COP heat-pumps.
www.adthermtech.com
=> adT heat-pumps ::: Advanced energy-recovery systems ===>>>
Sponsored links
  #9
Old 01-02-2010, 03:57 AM
VIP Poster
He will not have consistant sub-cooling, (if any at all)
Remember in the service world we do not use highly calibrated measuring instruments. And if they were, after a while being thrown around a service van, they will not be so much calibrated as estimated
  #10
Old 01-02-2010, 04:02 AM
desA's Avatar
VIP Poster
I'll get back in my hole, now...
__________________
www.adthermtech.com
  #11
Old 01-02-2010, 04:07 AM
VIP Poster
And i bet she better looking than mine??
  #12
Old 01-02-2010, 04:42 AM
desA's Avatar
VIP Poster
^ Hahaha... where the 'blush' emoticon?
__________________
www.adthermtech.com
Sponsored links
  #13
Old 01-02-2010, 07:01 AM
improving poster
Hi mate,
cheers
I think the reason you are seeing the system hunt, is because everything on your system has a fixed constant - outdoor fan speed control, compressor and an orifice. If you had a tev and fan speed control, I think you would see the system run a lot more smoothly, but still short of gas.
Also gary is right, If you imagine your hot gas running through your condenser and in to your liquid line, if the liquid line is not full it goes through the condenser too quick and does not sub cool enough.
That is why you are only seeing 3k sub-cooling. If you add more refrigerant and you have a full liquid line, the refrigerant is backed up in the condenser a little longer, enough to be sub-cooled to a reasonable level i.e 10k. I have found that if my condensing temperature is 45*c ,I would normally have a liquid line temp of around 35*c (not always spot on, but around that)
Hope this helps.
Troy
  #14
Old 02-02-2010, 01:09 PM
aquasanj's Avatar
rookie poster
Thanks fellas,
Did as per your advice and charged up 330 gms to correct the situation. Apparently whatever i reclaimed was obviously not the correct charge.
Re measured the piping length and topped up to superheat and all seems to be well now.
The super heat and sub cooling are obviously varying as the load changes
Many thanks guys for all your advice,
much appreciated
sanjay
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Fixed orifice woes Stiff Nipples Air Conditioning 8 18-08-2009 04:53 AM
Compressor loading, cooling, and range of operation. Air duster Fundamentals 10 02-04-2008 08:39 AM
Cooling tower evaporation, blowdown, makeup and cycles miltbeychok Industrial 5 14-10-2005 06:34 PM
Cooling tower evaporation, blowdown, makeup and cycles miltbeychok Fundamentals 0 13-10-2005 05:14 AM
PC cooling project status update + TEV questions. DaBit Technical Speculations 9 28-06-2002 04:03 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
