QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 10-05-2001, 03:19 AM
Jai's Avatar
Jai Jai is offline
rookie poster
Jai is on a distinguished road
Thumbs up
Hi guys, I'm new to this forum but I think it's a very informative site. I would like to get some feedback on the reliability and problems of scroll compressors.Recently we have lost 4 scroll compressors due to what seems to be a lack of lubrication.These compressors were from different systems with no apparent "system" problems.
  #2
Old 11-05-2001, 12:56 AM
acman's Avatar
acman acman is offline
improving poster
acman is on a distinguished road
Cool
Check rotation.Read amps.If 3 phase,reverse phases.
Sponsored links
  #3
Old 11-05-2001, 02:06 AM
Jai's Avatar
Jai Jai is offline
rookie poster
Thumbs up Scroll problems
These systems were commissioned about 9 months ago and 2 out of 4 compressors failed after 5 months.The system is a York package Liquid chiller with 2 independant refrigerant circuits of 2 compressors each.When the system was started-up,the voltage,rotation,superheat,oil level,pressures etc. were verified.Also a voltage monitor with phase reversal protection was installed.What I found odd is that I had to add 2 gallons of oil to the system and the oil level remained low.Seems as the compressors were pumping the oil out. I am presently working on 2 York Scroll systems and it seems as the compressors are pumping the oil out.I have already added 3 gallons of oil to these systems and the oil level is still low. I have never had this problem with recips. unless its a system problem. I'm trying to find out if other techs. out there are having the same problem.
  #4
Old 11-05-2001, 02:19 AM
Prof Sporlan's Avatar
Prof Sporlan Prof Sporlan is offline
Moderator
Prof Sporlan is on a distinguished road
Keep in mind that the oil you are adding to the system isn't disappearing..... the oil is likely residing in the chiller. An appropriate question to ask at this point is why the oil isn't returning back to the compressor.
__________________
[b]Prof Sporlan[/b]
  #5
Old 12-05-2001, 01:02 AM
Gary's Avatar
Gary Gary is online now
VIP Poster
Gary will become famous soon enough
I agree, Prof. It isn't that the oil is pumping out of the compressor. The problem is that it isn't returning. Adding oil to a system is almost always a mistake.
__________________
Author of TECH Method troubleshooting books
  #6
Old 12-05-2001, 03:19 AM
Jai's Avatar
Jai Jai is offline
rookie poster
Thumbs up
Gary I agree with you and Prof. Sporlan where the oil can be leaving and not returning.What does not seem to make sense is the fact that this is a package chiller so there is no "external" piping to cause oil return problems. Also the load in the evaporator is not lower than normal.(the g.p.m. is running slightly higher than design). Is there a tendency for Scroll compressors to circulate more oil through the system than Recips.
  #7
Old 12-05-2001, 03:47 AM
Gary's Avatar
VIP Poster
I know of no particular tendency for scroll compressors to circulate more oil, and the fact that you keep adding more and it doesn't come back should tell you something.
Designed by the manufacturer doesn't necessarily translate to perfect design, although they tend to learn from their mistakes. Perhaps you are witnessing some of their mistakes.
I would want to look very closely at the suction line sizing/sloping/trapping, as well as the chiller barrel flow pattern. Ask yourself, "Where is the low spot that is trapping the oil, while the refrigerant flows above it".
As the Prof points out, it hasn't disappeared, it is hiding somewhere.
__________________
  #8
Old 13-05-2001, 10:15 PM
Brian_UK Brian_UK is online now
Moderator
Site Moderator : and general nice guy
Brian_UK will become famous soon enoughBrian_UK will become famous soon enough
We had to change out a compressor on a Daikin packaged chiller during last summer. One team started and I had to finish the final connection and get it running again.
Found a lack of gas flow due to the discharge line up to the TEV being full of oil.
Problem appeared to be bad location causing high pressure trips during hot weather....probably pumped out the oil and killed the compressor that way.
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
Sponsored links
  #9
Old 26-06-2002, 03:59 AM
Preston Roy Powell's Avatar
Preston Roy Powell Preston Roy Powell is offline
rookie poster
Preston Roy Powell is on a distinguished road
Scroll losses!!
First ckeck you line size.. Then ckeck your super heat back to the compressor.
1. DId the compessor ground out!!
2. Are slugging the compressor
3. Are you starving the compressor.
__________________
Preston Roy Powell
[url]www.thinkcool.net[/url]
  #10
Old 26-06-2002, 06:07 AM
Dan's Avatar
Dan Dan is online now
Moderator
Dan is on a distinguished road
[quote]Found a lack of gas flow due to the discharge line up to the TEV
being full of oil. [\quote]
  #11
Old 28-06-2002, 08:36 PM
stevec's Avatar
stevec stevec is offline
rookie poster
stevec is on a distinguished road
One might expect some of the oils to come back to the compressor when it starts warm. Unless it is on 24 hr operation.You couls also check water flows etc.
One of the intersting points here being raised also is putting in oils when you can't see it on the ground!!! or ceiling or anywhere.
I have problems sometimes with some of our guys who believe if oil level is low it needs oil. As you all suggest step back and re focus.
  #12
Old 08-10-2009, 08:52 PM
install monkey's Avatar
install monkey install monkey is offline
Registered User
Hey, I am new to : RE
install monkey is on a distinguished road
Re: Scroll problems
have you done acid test on each circuit ,were drier cores,contactors changed with new compressors,are the compressors short cycling,condenser coils clean,tev functioning correctly.mains problems on site???????????????
Sponsored links
  #13
Old 08-10-2009, 09:35 PM
El Padre's Avatar
El Padre El Padre is offline
regular poster
El Padre is on a distinguished road
Re: Scroll problems
You could try isolating one circuit to ensure compressors are running at 100% capacity which will ensure maximmum oil return, is there an oil return line from the evaporator?
__________________
Tutto il Mondo e un Paese
  #14
Old 08-10-2009, 10:04 PM
El Padre's Avatar
regular poster
Re: Scroll problems
Just a thought, is there a water flow problem on that site, did they leave flow rate measurements on the commissioning sheets? If you post the model number one of the Yorkies might be able to give you more information.
__________________
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Suction pressure problems on TS units at low ambient temps nova Transport 10 18-03-2006 08:35 PM
Problems LG don't want you to know about Andy W Air Conditioning 11 16-02-2006 05:52 PM
Oil return problems Peter_1 Industrial 37 23-08-2004 11:30 PM
Scroll Compressor dwallan Commercial 1 30-07-2001 04:18 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
