QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 23-08-2003, 08:52 PM
Latte's Avatar
Latte Latte is online now
VIP Poster
Latte is on a distinguished road
Question Help Needed Mitsi MSC07RV/MUH-07RV
I'm Confused
I need help with a Mitsi indoor unit MSC07RV. I have only had a very quick look at it but there are two LED's on the front of it.
the left one flashes continuasly (SPELLING ?) the RH one doesn't light up at all. The outdoor unit doesn't do anything either. there is power on the 3 phase input but nothing on the two wires next to it from the indoor unit. There looks like a reset button under the fron cover next to the filters but i have pushed this and nothing happens, also i have tried switching the indoor unit off and on again & still the same.
Does anyone have any ideas where to start, I know somehow you can make the lights flash to give you a clue whats hapening but the stickers are missing inside the panel and all i can make it do if flash the LH LED continuesly.
Any help would be appreciated, i have looked on Mitsi's website but you can't get any technical info off of it
  #2
Old 24-08-2003, 11:28 AM
cooltrain's Avatar
cooltrain cooltrain is offline
improving poster
cooltrain is on a distinguished road
First try to make sure that the thermostat or controller is set to the correct MODE, TEMP SETPOINT and timer.
Find the error code of the flashing LED. It denotes the error if there is any.
Sponsored links
  #3
Old 24-08-2003, 03:00 PM
Mark's Avatar
Mark Mark is online now
Moderator
Site Moderator : and general nice guy
Mark is on a distinguished road
mitsu a/c
hello rdocwra
firstly have you fitted your gauges?the control signal on the mitsubishi is 12v between indoor and out door unit
The faults on indoor unit as follows
P1 intake air sensor abnormal (terminals cn20 on pcb).
P2 indoor pipe sensor abnormal (cn21).
P3 transmitting/recieving signal error.
P4 abnormality of drain sensor (cn50).
P5 malfunction of drain pump.
P6 coil frost/over heat protection.
P7 system addressing error
P8 outdoor unit malfunction.
or out door unit faults
LED 1 flashing. reverse phase
LED 2 flashing. open phase
LED 3 flashing. pipe sensor short/open circuit.
LED 4 flashing. high pressure switch.
LED 5 flashing. over current relay
LED 6 flashing. thermal switch (check gas charge)
LED 7 flashing. overheat protection (out door fan motor)
If you need any more info email me,
kind regards
mark
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Autocascade refrigeration system: design verification needed DaBit Technical Speculations 1 28-12-2006 01:02 PM
Mitsi Problems Latte Air Conditioning 9 12-02-2005 08:22 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
