QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 21-07-2003, 12:46 PM
David PS's Avatar
David PS David PS is offline
improving poster
David PS is on a distinguished road
Water Chiller Control
We were asked to look at a chiller with control problems.
It is a stand alone unit which serves two ahu. The unit operates when a set of external volt free contacts complete a circuit.
Chilling to the ahu is controlled by the BMS and mechanical valves.
The external contacts are controlled via a small pressurization unit, which consists of a header tank, pump and high & low pressure switches.
The pressurization unit pumps is connected via water piping to the chilled water ring.
Can anyone shed any light as to how the control logic is meant to work.
David
  #2
Old 21-07-2003, 07:57 PM
David PS's Avatar
improving poster
The pressurization unit mainly, leading on to the chiller.
Sponsored links
  #3
Old 29-08-2006, 09:14 PM
mgtet's Avatar
mgtet mgtet is online now
improving poster
mgtet is on a distinguished road
Re: Water Chiller Control
What sort of control problems are you getting? I can't see the pressurization unit sending the enable signal though although it might be an interlock. I would suggest attending site with the controls company to determine which is at fault, the chiller or the controls.
  #4
Old 29-08-2006, 09:29 PM
Peter_1's Avatar
Peter_1 Peter_1 is online now
Moderator
Site Moderator : and general nice guy
Peter_1 will become famous soon enough
Originally Posted by David PS View Post
...The external contacts are controlled via a small pressurization unit, which consists of a header tank, pump and high & low pressure switches.
This needs a small schematic because I don't understand your set-up.
I think others think the same and if the question is already difficult to understand, then the possible answer will also be wrong or direct you in the wrong direction.
__________________
  #5
Old 29-08-2006, 11:14 PM
Brian_UK Brian_UK is online now
Moderator
Brian_UK will become famous soon enoughBrian_UK will become famous soon enough
Have to say folks that we have missed this post somewhat.
As it is over three years old I would imagine that he has resolved the matter by now
__________________
Brian
PERCUSSIVE MAINTENANCE. The fine art of whacking the crap out of a piece of kit to get it to work again.
ʎɐqǝ uo pɹɐoqʎǝʞ ɐ ʎnq ı ǝɯıʇ ʇsɐן ǝɥʇ sı sıɥʇ.
"You know "that look" women get when they want sex? Me neither." --Steve Martin
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Chiller Control tabtech Air Conditioning 0 09-07-2006 11:40 PM
Mcquay PES Flooded Water Cooled Screw Chiller Brian Technical Speculations 4 05-07-2006 09:43 PM
water chiller andrewuk Technical Speculations 9 17-10-2005 09:28 PM
Building a wine cabinet Rory Technical Discussions 38 13-07-2004 08:28 PM
water chiller dwallan Air Conditioning 3 12-12-2001 04:17 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
