QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 08-07-2003, 02:59 AM
rlim's Avatar
rlim rlim is offline
Registered User
Hey, I am new to : RE
rlim is on a distinguished road
Lightbulb reduce thickness of bended copper tubes
We have plans to reduce the thickness of the plain copper tubes, sizes ranges from 1/4" to 3/4" OD x 0.028" (0.71 mm) thickness and we plan to change the thickness to 0.022" (0.55mm) for some reasons. These plain copper tubes used in suction and discharge tube in window air conditioner unit.
I would like to know if these are posible? I would like to know some formulas to calculate if the thickness is possible especially in the bended part since there will be reduction in thickness.
Coul somebody help me regarding this matter.
  #2
Old 08-07-2003, 06:17 AM
Dan's Avatar
Dan Dan is offline
Moderator
Site Moderator : and general nice guy
Dan is on a distinguished road
It would help to know why you are attempting to make the pipe walls smaller.
Sponsored links
  #3
Old 08-07-2003, 09:54 AM
rlim's Avatar
Registered User
cost reduction... since we were buying copper tubes per weight we can save at least 18 % to 20 % cost reduction. But before we apply this one we would like check if possible by computation... and also we don't want to create quality problem.
  #4
Old 08-07-2003, 10:41 AM
biffdecki's Avatar
biffdecki biffdecki is offline
Registered User
biffdecki is on a distinguished road
rlim
Hope this link helps you somewhat, there is pipe thickness formula info on the BRA factfinder 5 although based on British Standards.
http://www.feta.co.uk/feta05d.htm
  #5
Old 08-07-2003, 10:58 PM
Prof Sporlan's Avatar
Prof Sporlan Prof Sporlan is offline
Moderator
Prof Sporlan is on a distinguished road
Manufacturers ultimately resort to performing a burst test or similar test to confirm the integrity of a component or small system. Tubing wall thickness, tube bending, and brazing technique all will affect the strength of the tube. Setting up a burst test on a window a/c unit using a hydraulic hand pump should be relatively easy.
__________________
[b]Prof Sporlan[/b]
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Heat transfer through tubes Peter_1 Fundamentals 3 27-03-2005 09:39 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
