Helping out a friend (by GOD, if I'm working on your air conditioner - you're a
good friend), I pondered the use of the single pole contactor (with the common bar on the other line). I just learned that the purpose of that congiguration is to complete the circuit through the crankcase heater which is wired across the (open) contact of the contactor, and "disable" the crankcase heater when the contacts are closed.
What amount of heat gain (or increased load) do you anticipate with the crankcase heater energized during compressor operation, in such a case as a two pole contactor be applied, and the heater connected to the line side of the contactor (always energized). ooops!
