QUICK LINKS
Home Contact Us FAQ
Go Back   Refrigeration-Engineer.com forums > REFRIGERATION DIVISIONS > Air Conditioning
RE
re
calibre
ashbury
rhl
richmond
RE1
Reply
Thread Tools Display Modes
  #1
Old 31-01-2003, 04:56 PM
zenman's Avatar
zenman zenman is offline
Registered User
Hey, I am new to : RE
zenman is on a distinguished road
Radiant cooling panel manufacturers
Can some body give some URLs for 'Radiant cooling panel manufacturers' which are internationally available please?
Don't these big guns carrier or trane make Radiant cooling panels? I could not find some thing of the kind on there websites. Or radiant heating panels are used as it is for cooling also?I have heard that this is more common in europe than US, then there must be some europian manufacrers specialising in it.
  #2
Old 31-01-2003, 06:44 PM
frank's Avatar
frank frank is online now
Moderator
Site Moderator : and general nice guy
frank is on a distinguished road
I think you are confusing chilled ceilings with radiant heating panels. Here is a link to an association whose members make and install chilled ceilings and beams. http://www.feta.co.uk/cca/
Frank
Sponsored links
  #3
Old 01-02-2003, 02:25 PM
david.findlay's Avatar
david.findlay david.findlay is offline
rookie poster
david.findlay is on a distinguished road
Do a search on Google for 'Radiant cooling panel manufacturers'
  #4
Old 02-02-2003, 03:06 PM
zenman's Avatar
Registered User
Thanks fellows for the advice and link. Chilled ceiling is radiant cooling I presume, or just a fancy name for chilled ceiling.
Bult after searching the web even through Copernic Pro I could get surprisingly little information aboput this mode of cooling.
though every where it is mentioned with very favourable remarks over forced convective cooling, but may be it need very large surface area for same cooling load or what?
Little frustrating.
  #5
Old 02-02-2003, 05:17 PM
frank's Avatar
Moderator
I don't think it depends on size but with any cooling system you have got to match the heat load for effective cooling.
As these chilled ceilings (or beams) operate on secondary refrigerant it is quite easy to regulate the flow through them and so the cooling duty can be controlled as the room load varies.
Frank
Sponsored links
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
radiant cooling and heating issue Lc_shi Fundamentals 2 29-05-2006 08:34 AM
cooling tower without fillings Lc_shi Fundamentals 3 27-12-2005 01:55 AM
Cooling tower evaporation, blowdown, makeup and cycles miltbeychok Industrial 5 14-10-2005 06:34 PM
Cooling tower evaporation, blowdown, makeup and cycles miltbeychok Fundamentals 0 13-10-2005 05:14 AM
Regulation of cooling capacity npaisnel Domestic 13 09-02-2002 12:22 AM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum and its pages must not be copied or reprinted without the written consent of Refrigeration Engineer.com.
This forum is a free and open discussion board.
Refrigeration-Engineer.com, the administrators and Moderators of this site are not responsible for content posted here.Ad Management by RedTyger
