Thread: Thermo King CB C1-10 C
30-07-2010, 06:34 PM #1
Gentlemen and Ladies,
Greeting to all fellow Reefer Men from here in Music City USA. I am in need for a schematic on an older Thermo King Unit.
The details:
M/N: CB C1-10
S/N: C423874592
B/M: 712978
R12 8.5 lbs
I replaced the Low-Pressure cut-out as it had a hole rubbed in the capillary line. I thought that was the only issue, but was incorrect in this assumption. I've checked the control board, diode, fuses, and all associated controls in the control panel and box. I can get the compressor to energize by applying 12V directly to the clutch assembly, but not automatically. The problem that I'm encountering is that all of the identifying nomenclature on the wires have been bleached out by the Sun... So, the dilemma that I face is akin to finding a needle in a needle stack...
I am an independent contractor and would greatly appreciate any help in this vexing matter.
Thank You,
Music City Ref
30-07-2010, 08:41 PM #2
30-07-2010, 09:05 PM #3
Hello djbe,
Thank you for the quick response
My email is:
sarnia_rocks@yahoo.com
Thank YOu in Advance for helping me get this unit back ion tip top shape!
Best Regards,
Music City RefLast edited by chillin out; 01-08-2010 at 12:59 PM.
31-07-2010, 08:01 PM #4
Re: Thermo King CB C1-10 C
Enter your email to send you a pdf file
Thermo King
By pkfo in forum Technical SpeculationsReplies: 2Last Post: 19-05-2010, 01:17 PM -
Thermo King SB 310 Manual
By Reefer tech in forum FundamentalsReplies: 1Last Post: 15-04-2010, 07:11 PM -
Thermo King Refrigerant Help!
By jingua_ph in forum TransportReplies: 43Last Post: 12-04-2008, 01:19 PM -
Thermo King v? 00 MAX Tc Wiring Diagram
By Chris2005 in forum TransportReplies: 3Last Post: 01-02-2006, 09:01 AM
