    Mar 2016
    IRAN
    182
    9
    Oil for unltra low temperature freezers
    Dear Guys ,
    Usually for HCFC we use Mineral such as 3GS/4GS of SUNISO brand and usually for HFC we use POE such as SL100/SL68 of SUNISO oils and it is common in my country.
    But these types of oils have low temperature working limited. It means we can use (If I do not do mistake) minimum to -50 or -60C.
    For ultra low temperature freezers my friends use these types of oils but I know that they mix them with other material as solvent.
    By this solvent they can use them to -120C in freezers.
    Do you have any experience about this ? Or do you know which material we should use as a solvent by oil to use in case of ultra low temperature compressors ?
    Thanks.
    11,025
    Re: Oil for unltra low temperature freezers
    Perhsps add some HC to move the oil../
    http://www.achrnews.com/articles/118...-refrigeration
    Mar 2016
    IRAN
    182
    9
    Thanks , It was interesting
