Results 1 to 50 of 135
20-08-2011, 02:49 AM #1
Re: How to assign thermodynamic properties after splitting two phase into gas and liq
Hi Chef, good to see you are looking into our little problem.
As far as enthalpy goes, if the vapor is just that vapour (full seperation) then the enthalpy will be on the saturation point of the curve. But how is entropy effected.???????
20-08-2011, 04:21 AM #2
Mad
Maybe 4:00 here, I'm not sleeping till I have exhausted my understanding or lack of
Trying to understand here full seperation
And by this I mean on the chart the point of seperation I can see
With (as you said) enthalpy following the curve of saturation/vapour
enthalpy tails off at the point of the opposite curve saturation/liquid
So (correct me) this point where enthalpy tails of is the point of entropy
The point of diss-order prior to order and the point at which you need to achieve full seperation
If this is correct, how do you physically get to this point to acheive seperation in the first place ?
And how would this be put to use ?
What sort of system (design) if possible to get to this point & what would this acheive ?If the World did not Suck, We would all fall off !
