Results 1 to 50 of 210
Thread: Carters Widget Revealed!
21-08-2011, 05:33 PM #1
Re: Carters Widget Revealed!
Just noticed this one again... Interesting.
The flashgas is taken into account for calculation of the net refrigeration effect.
Will try to explain my vision: all the bubbles together present at the exit of the TXV have a certain mass at a certain enthalpy. During the pass through the evaporator, they will absorb heat, so the enthalpy will change and....
No, wrong Peter, twisting my brain again,..If it's already 100% gas and we add heat, then it becomes superheated. The bubbles are already at a complete gaseous phase, surrounded by liquid which still can absorb heat, So, the flashgas is already at the condition like we will find finally all the liquid on the right side of the saturated curve. Due to the fact that the flashgas is already 100% gas, it must be positioned on the right side of the curve.
What's Carters Widget, a little bit difficult for me to translate..what's widget anyway?Last edited by Peter_1; 21-08-2011 at 05:35 PM.
21-08-2011, 09:01 PM #2
21-08-2011, 10:05 PM #3
21-08-2011, 10:20 PM #4
Removed as so - not to confuse the thread - with another
Last edited by chillerman2006; 21-08-2011 at 10:33 PM. Reason: Removed as so not to confuse the thread
