Results 1 to 50 of 224
Thread: Strange TXV setup
21-03-2010, 04:08 AM #1
Re: Strange TXV setup
Adding charge drops the SH (drops the suction line temp). So...
Insulate the bulb and add charge. The suction line temp will drop until the bulb temp is below the TXV temp and will thus regain its charge. If the SC is then excessive, there is a restriction.
A restriction could be an undersized or kinked liquid line, plugged TXV inlet screen, restrictive HX, etc..
21-03-2010, 04:26 AM #2
Except if his Madness is right (usually is) the #4 is too big and works only with migration so if the bulb is allowed to regain control it might not be able to turn down enough.
So put in a smaller orifice and wont wont work properly till the bulb eventually gains control if it ever does.
Not sure I like that scheme of things
Chef
21-03-2010, 04:42 AM #3
Can't suss strange paramaters on Denco downflow unit
By Coolie in forum Air ConditioningReplies: 20Last Post: 26-07-2010, 03:20 PM -
The Basic Setup
By ice_cold in forum FundamentalsReplies: 5Last Post: 17-12-2009, 09:34 AM -
Fujitsu strange Whistling noise
By gwilliamson in forum Air ConditioningReplies: 17Last Post: 26-03-2008, 09:48 PM -
Hermetic strange sound.
By fridg in forum Technical SpeculationsReplies: 16Last Post: 02-03-2008, 07:08 PM -
strange inverter problem
By rbartlett in forum Air ConditioningReplies: 11Last Post: 19-05-2006, 08:31 PM
