Results 1 to 50 of 596
28-05-2013, 02:27 PM #1
Re: all reefer container problems/daikin/carrier/thermoking/mitsubishi
Hello...no the problem isnt solved yet as it only seems to trip the CB when its very hot (+40c). Its works well day after day when its below this ambient temp. I have set the amps to 21. Its not an isolated case and can be common as the summer draws near here in the middle east. I am constructing some shading to see if that helps.
28-05-2013, 02:53 PM #2
you can chat with me via reefermechanic@yahoo.com ? see you , reefer mechanic.
28-05-2013, 03:25 PM #3
Container Reefer Unit for Controlled Atmosphere (CA)
By reeferman in forum New TechnologiesReplies: 9Last Post: 26-08-2011, 09:26 AM -
Help cutting open 40ft reefer, we now have problems
By adrian_uk17 in forum IndustrialReplies: 50Last Post: 28-11-2010, 08:11 AM -
Reefer container
By stevec in forum CommercialReplies: 2Last Post: 25-01-2009, 05:30 PM
