Results 1 to 13 of 13
    Feb 2010
    32
    A qustion about compressors on domestic refrigeration.
    Hi.
    Can someone tell me how you can identify on a compressor the technical info on it i.e. H/P etc.
    Just that I can never find this info on the label usually but maybe I am mistaken.
    Sorry if it is a daft question but I am just curious.
    Thanks in advance.
    Bobby.
    May 2009
    Sydney
    73
    Re: A qustion about compressors on domestic refrigeration.
    Model number on compressor will enable you to ascertain size and suction pressure range.
    Usually check the model number from the label with the manufacturers information is the safest way.
    Jan 2003
    East Anglia
    1,160
    to be honest there is no rule of thumb, different manufactures use different methods. Probably the easiest thing to so is go to an HRP or Climate centre and pick up a catalogue. These then show the most common makes and what the letters stand for. If however you want details on a certain compressor, post the details on here and we can help. Usually the big numbers on the top are what we need for instance :-
    Danfoss TL5 or
    L'unite CAJ2464z or
    Aspera ####### etc
    Hope this make sense
    Feb 2010
    32
    Hi all.
    Thanks for the replies.
    As a for example, a Danfoss compressor which has a number on it of SC15F. How & what can I tell from that?
    Cheers.
    Bobby.
    Feb 2010
    32
    Aha. I think I have an answer to my question above. The 15 signifies 15cc displacement. Am I right? Do the letters identify the HP in some way?
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by Bobby Drake View Post
    Hi.
    Thanks in advance.
    Bobby.
    Hi have a look at this
    http://www.danfoss.com/businessareas...a40e4e59d.html
    Mar 2010
    uk
    43
    2
    I've tried to get diffrent cheaper alternative compressors for domestics. Getting details of the old compressor and using google to find the h/p or watts. but u can get two compressor of same horsepower but they give diffrent performances. Over time i've found reliable,cheap compressor that are specific for each fridge
    Split Croatia
    6,151
    Quote Originally Posted by Mck-uk View Post
    Compressors are pumps and if they have same displacement and same area of usage (motor power) than they will perform same.
    Those two are key criteria for finding suitable replacement compressor.
    HP doesnt mean anything without conditions for which are HP given. If conditions, are different you are comparing apples and pears.
    Split Croatia
    6,151
    No, and HP is misleading! Don't care for HP. You only need exact same displacement (if you don't want capillary adjustment) and pretty much same motor power. Motor power for same displacemant could be diferent acording to usage (low evaporation temperatures, medium ET, high ET, AC ET). Your replacement compressor of same displacemant need to have motor for same usage area.
    http://www.ra.danfoss.com/TechnicalI..._ei050a102.pdf
    Details of your SC15F, for example.
    http://www.ra.danfoss.com/TechnicalI...3_Cd44h502.pdf
    Feb 2010
    32
    So HP is irrelevant. It is the displacement in cc & power in wattage that is important, yes?
    Split Croatia
    6,151
    Yes, power of motor and cc and type of motor starting (LST for capilary systems and HST for expansion valve)
  1. Refrigeration Compressor Data
    By mvh18 in forum Industrial Compressors
    Last Post: 04-01-2010, 08:49 PM
  2. Domestic Refrigeration Training
    By Kev_Brown in forum Training
    Last Post: 29-01-2009, 07:36 PM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. refrigeration stress
    By wellcold in forum Chit Chat & Service Stories
    Last Post: 13-12-2001, 03:56 AM
