Results 1 to 50 of 72
Thread: charging R410a with no vacuum !!
04-09-2010, 12:27 PM #1
Re: charging R410a with no vacuum !!
04-09-2010, 09:36 PM #2
I told problem start at 15 degree and get worse with lower temperature. Where did you get 30 degree from?
Check a diagram for boilingpoint of water and a IX-diagram for condensation if you dont understand what i talk about. (you obviously dont)
Yes.. i teach technicians sometimes.
05-09-2010, 11:50 AM #3
Vacuum Pump Questions
By position1 in forum FundamentalsReplies: 7Last Post: 08-10-2009, 02:33 AM -
Vac Down Procedure.
By mendoza in forum FundamentalsReplies: 3Last Post: 26-09-2009, 04:19 PM -
Troubleshooting a vacuum pump and gauge set.
By Old Codger in forum FundamentalsReplies: 7Last Post: 08-08-2008, 05:13 PM -
inverters pulling vacuum
By bangoman in forum Air ConditioningReplies: 2Last Post: 05-02-2008, 09:12 PM -
charging R410a
By cikku in forum RefrigerantsReplies: 25Last Post: 05-12-2005, 12:32 AM
