Thread: Oil in condenser water
Threaded View
19-10-2015, 09:24 PM #4
Re: Oil in condenser water
If the condenser tubes are leaking, once the refrigerant has leaked away then the water will get into the system , causing a lot of expensive damage to the machinery. So until you can check the condenser for leaks I would immediately drain the water side of the condenser to eliminate the possibility of contaminating the whole system with water. Its safer and less expensive to repair if the condenser is faulty.
