    rbartlett's Avatar
    rbartlett Guest
    410a refrigerant burns
    guy's
    has anyone else noticed that 410a seems to burn far more than any other refrigerant?
    almost every time i remove my gauge lead i end up with a burnt finger(s). I know I'm not doing anything different to 22 or 407c etc so it must be the gas...
    cheers
    richard
    Oct 2006
    1,843
    Re: 410a refrigerant burns
    Quote Originally Posted by rbartlett View Post
    guy's
    cheers
    richard
    I've not had the pleasure of being burnt by it yet
    This may be too simple but do you think it could be because it is so cold compared to R22 at ambient. Its about 20degc lower.
    Cheers taz.
    Mar 2006
    kent
    49
    22
    or maybe that it is a million psi higher than r22 so you have a million psi more in your guage line!or maybe you didnt follow the instruction that b&q gave you when you bought the unit.sorry i`m having a bad day.
    I trust that you are using protective gloves and shut off valves on your gauge lines there Richard
    Oct 2006
    1,843
    Valves on 410 gages are good and we all know we should always wear gloves
    taz.
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    Yeah, I had a nasty nip from R410 this Summer. Because of the higher pressure it is more difficult to unscrew my connectors and allows more refrigerant to escape, in this case getting cold enough to freeze the skin even in my gloves, because my gloved are quite short, liquid refrigerant managed to get around my watch strap and make a real mess of my wrist. I have bought a couple of quick connectors for R410 from RPW but they will only connect to 1/4 inch flair hoses
    Karl
    Feb 2006
    derbyshire
    610
    i too had a taster,had to remove someone elses gauges without shut off valves, wakes you up a bit.
    Dec 2005
    Cheshire
    264
    Get the quick coupler set from SRW, I've had them for 2 years now, never had a cold burn since
