Results 1 to 50 of 67
Thread: Fujitsu-General Fault
22-09-2008, 09:37 PM #1
Re: Fujitsu-General Fault
Ok been back. I got mucho info.
Serial Signal Test (First diagram posted by Nike)
Between terminal 1-3 170-200V. I think this is too high as the diagram says 70-130V.
AFM Test: (As the second diagram posted by Nike)
+ - 360KΩ (correct)
- N1 0.3Ω
P + 330KΩ
L1 L2 361KΩ
P N1 0.3Ω
L1L2 Control ∞
L2 N2 ??? (I could not find the N2 terminal)
L2 P 0.3Ω
p L2 0.3Ω
All these bar the first and test to the control box are nowhere near what they should be
As a side note, I tested the leads on the multi-meter and they read 0.3Ω.
Finally the fan motor. The motor is not the same as the one posted by Nike. I posted the winding readings earlier in this thread.
This is what I have.
So after all this I think the AFM is screewed. Do we all agree?
22-09-2008, 10:11 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
fujitsu vrf fault
By leegally1983 in forum Trouble ShootingReplies: 8Last Post: 05-09-2008, 03:13 PM -
Fujitsu AUY25 Fault
By Radlam in forum Air ConditioningReplies: 9Last Post: 12-05-2008, 01:52 AM -
01 fault on fujitsu
By pacman in forum Trouble ShootingReplies: 7Last Post: 04-11-2007, 07:25 AM -
Fujitsu AOT24PMAL Fault Codes
By johnmart in forum Trouble ShootingReplies: 5Last Post: 19-04-2004, 06:39 AM
