Results 1 to 13 of 13
Thread: micron to mm
15-12-2008, 10:34 AM #1
micron to mm
Hi all,
How to convert 200 micron to mm.
Thanks & Regards
15-12-2008, 10:58 AM #2
Re: micron to mm
it is simple 1 mm= 1000 micron
so 200 micron is 0.2 mm
16-12-2008, 05:14 AM #3
Re: micron to mm
Thanks for the info. it's indeed simple.
16-12-2008, 07:20 PM #4
Re: micron to mm
There is a vacuum conversion chart here which may be of interest...
http://www.engineeringtoolbox.com/va...ter-d_460.htmlBrian - Newton Abbot, Devon, UK
16-12-2008, 08:04 PM #5
18-12-2008, 06:11 AM #6
Re: micron to mm
Thks Brian,
It's useful to me.
19-12-2008, 07:14 PM #7
Re: micron to mm
Just what i was looking for i was trying to convert 6mm Hg to microns Which means it is 6000 microns.
ThanksThe difference between genius and stupidity is that genius has its limits.
Marc
19-12-2008, 07:26 PM #8
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
20-12-2008, 04:39 AM #9
25-12-2008, 12:15 PM #10
Re: micron to mm
How did you know .
Its for a presentation i was doing for college.Last edited by marc5180; 26-12-2008 at 10:03 PM.
Marc
25-12-2008, 01:43 PM #11
Re: micron to mm
Brian,
many thanks for the site.one i'm looking for.
regards,abet
02-01-2009, 07:15 PM #12
Re: micron to mm
Hi, all
1 bar is 760 mmHg (or 760 Torr), if we divide 1/760= 0,00131578947368 bar = 1 Torr
The last inch (from 29-30 actually from 0-1) of vacuum is equal to 25400 microns. The micron then is a much more precise method for measuring deep vacuums. 1 micron = 0.001 ...
.... an informal unit of pressure widely used in vacuum technology. In this use, a micron is a micron of mercury, that is, 0.001 mm Hg or approximately 1.333 microbars (µbar or µb) or 133.3 millipascals (mPa). For all practical purposes, 1 micron is identical to 1 millitorr (mTorr).
Best regards, Josip
05-01-2009, 11:11 AM #13
Re: micron to mm
Thanks for the link Brian.
Oil Filter micron
By Iceehot in forum NH3Replies: 16Last Post: 26-09-2008, 02:49 AM -
accepable levels using a Micron gauge
By kengineering in forum CommercialReplies: 24Last Post: 06-12-2007, 11:50 AM -
Humidifiers with 1 micron droplet size
By sharshal in forum Technical DiscussionsReplies: 12Last Post: 11-05-2007, 07:35 PM -
Help-oil life time
By Josip in forum Technical DiscussionsReplies: 4Last Post: 09-05-2006, 01:01 AM -
Oil parameters
By Kevin S in forum FundamentalsReplies: 7Last Post: 08-10-2005, 04:46 PM
