Results 1 to 28 of 28
Threaded View
04-04-2015, 07:50 PM #4
Re: zanotti bgm11702f/abr mono bloc system icing up
Also had same as above only thing would say if building ice between coil and fan it could be more to do with moisture in room ie leak in insulation because ice is not on coil perhaps the Df is not the issue I have had this happen twice on a zanottie once because of badly build room and one because the side panel on evap was not screwed in correctly and unit pulled air out the side rather than through the coil
