Results 1 to 10 of 10
Thread: HP to Tons
14-06-2009, 05:23 AM #1
HP to Tons
Hi Good day!
Im just hoping someone who can teach me to convert HP of ACU to TR
Someone told me that 2.5HP of ACU is also a 3TR ?
Any formula for this?
thank you
Dongbadz
14-06-2009, 07:14 AM #2
Re: HP to Tons
(1) is compressors today are rated by BTUS not by HP.
Lets say ZR36K means 36900 BTUS @ 45F over 105F liquid.you have to look on the envelop of the compressor. That compressor is 2 3/4 HP.
HP is for the past
14-06-2009, 07:21 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Re: HP to Tons
When you converting HP to TR as power units than 1HP is 0.212 TR.
But if you trying to convert absorbed power of compressor to refrigeration capacity, than you must consider COP of refrigeration system. If we presume usual COP of AC system of ~3 (although some modern small split-systems have COP of 4,5 or more) than your formula is like this:
TR= HP compressor*0,212*COP
1HP=1*0,212*~3=~0,64TR
14-06-2009, 07:24 AM #4
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Re: HP to Tons
BTU is also past!
SI units are future.
Watt is SI unit for power.
14-06-2009, 10:58 AM #5
Re: HP to Tons
Dear All, Thanks for the prompt response....
Dongbadz
14-06-2009, 03:35 PM #6
Re: HP to Tons
I disagree with all of you,
There is no way to convert HP > TR and COP will not add much,
Its all in the evaporating temperature, head pressure and ambient temp. { and that is if, lets say, the system has been designed perfect}
A 10 HP compressor [maneurop 124] will give output of 7.74 KW at -30° evaporation temp and 42.135 KW at 10°C evaporation. Now, thats only at 27°C ambient...... It will be a different story altogether when the ambient will rise to 45°C.
So?????????? How do you convert now?
14-06-2009, 10:11 PM #7
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
15-06-2009, 01:52 AM #8
Re: HP to Tons
Originally Posted by nike123If all else fails, ask for help.
15-06-2009, 04:02 AM #9
Re: HP to Tons
Thank you for the idea... can you send t us the proper way to convert it?
It will be highly appreciated.
thanks a lot
15-06-2009, 05:08 AM #10
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Re: HP to Tons
Tons of Information - HVAC
By harsen in forum Refrigeration BooksReplies: 20Last Post: 03-05-2009, 10:00 PM -
Tons of Refrigeration
By benncool in forum Air ConditioningReplies: 19Last Post: 29-04-2009, 10:22 PM -
evaporator leaving temp too high in trane centravac chiller with 1350 tons capacity
By chillout_rg in forum Trouble ShootingReplies: 11Last Post: 05-07-2008, 02:52 AM -
Is anybody know how many tons LENOX coil model no
By frankfrank in forum Technical SpeculationsReplies: 2Last Post: 22-06-2008, 09:53 PM -
pipe size vs tons of refrigeration
By vives120 in forum Technical SpeculationsReplies: 12Last Post: 01-05-2006, 08:42 AM
