Results 1 to 24 of 24
19-03-2009, 10:41 PM #1
Re: Pool heat pump water side diagram
One thing to be aware of Nike.
Will the pool chemicals, chlorine etc., affect the metals of the desuperheater?Brian - Newton Abbot, Devon, UK
20-03-2009, 05:30 AM #2
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
It is not direct heat transfer. It first heat water in closed loop, and at pool side is going to be second heat exchanger for pool water heating of proper material (titane, I think). It is going to be supplied and installed by original pool equipment installations company.
cold river water
By eftimios in forum FundamentalsReplies: 8Last Post: 09-11-2008, 06:37 PM -
Home designed and built heat pump!
By The MG Pony in forum Heat PumpsReplies: 15Last Post: 17-08-2007, 02:01 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM -
Mcquay water source heat pump
By bernie in forum Air ConditioningReplies: 2Last Post: 10-02-2003, 01:53 AM -
Water Source Heat Pump
By aliugur in forum FundamentalsReplies: 1Last Post: 02-06-2002, 03:24 PM
