Results 1 to 50 of 130
29-01-2011, 05:59 PM #1
Re: Home made swimming pool heat pump
29-01-2011, 06:11 PM #2
03-02-2011, 09:51 PM #3
Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
29-01-2011, 06:23 PM #4
29-01-2011, 06:31 PM #5
I've seen this happen with copper cold water pipes that were connected to galvanized iron fittings. I went into a customers garage and there was a fine mist of water being sprayed from the numetous micro perforations in the pipe. How it hadn't burst I'll never know. The whole length was pretty much the same. Water conducts electricity.
Also, years ago my dad worked for the gas company in the UK. In the late 60's/early 70's there was a shortage of copper pipe so they decided to install central heating with steel pipe. Total disaster, it all had to be ripped out and replaced due to electrolysis destroying the steel pipe.
Seeking Tips on Getting the Most from a Heat Pump
By kenelias in forum New to REReplies: 4Last Post: 29-11-2010, 08:52 PM -
Pool Heat Pump
By elvis in forum Heat PumpsReplies: 5Last Post: 23-03-2010, 09:18 PM -
Capacity control
By sparrow in forum TrainingReplies: 44Last Post: 18-01-2010, 07:49 PM -
Home designed and built heat pump!
By The MG Pony in forum Heat PumpsReplies: 15Last Post: 17-08-2007, 02:01 AM -
Heat pump made from a TM-15HD?
By The MG Pony in forum TransportReplies: 8Last Post: 18-05-2007, 07:37 PM
