Results 1 to 50 of 69
Thread: display case evaparator fans
Threaded View
03-04-2007, 10:10 AM #11
Re: display case evaparator fans
Found 3 sitting in the plantroom of a r744 store I commissioned about a year ago, all 3 seemed to have seized, or at least were binding really bad, don't know what the symptoms were though, just saw them lying there after being replaced - they were out of MT cases. Were used in one speed only (2000rpm), I guess that's not a ringing endorsement for them but you usually don't change evap fan motors that quick. Give them a few years and they'll drop like flies over here, the two big chains are really hot and cold with their case cleaning schedules and I can see the little USB ports filling with water easy (even though its a waterproof plug).
Tinkering with an old Ref glass display case
By fix_it_man74 in forum Trouble ShootingReplies: 3Last Post: 07-08-2006, 02:35 PM -
Need help with a dual compressor display case
By kengineering in forum Technical DiscussionsReplies: 15Last Post: 15-03-2006, 07:32 PM -
display case temp alarms
By shark26 in forum Supermarket RefrigerationReplies: 9Last Post: 17-01-2006, 10:07 AM -
Fogal Open Display Case
By Abe in forum CommercialReplies: 2Last Post: 07-05-2005, 08:47 PM -
Big Display Case
By Abe in forum CommercialReplies: 4Last Post: 02-07-2003, 10:53 PM
