    Jan 2008
    Durban
    Question water chiller question
    I have a question about water chillers.
    I want to build up a 7Kw water chiller.
    I am building a small water tank with glycol, the glycol will be cooled by a brazed plate heat exchanger using refrigerant as the primary cooling.
    In that tank I want to run a length of 3/8" copper pipe in that tank to cool down water running to another application.
    Does anyone have information on how to work out the total length of pipe i will need
    5,667
    Re: water chiller question
    You are going to have to provide a lot more information before any calculations can be done, such as:
    What are the expected cooling water entering and leaving temps (T1, T2)
    How big is the load you are cooling
    What temp is the refrigerant evaporating at
    How much water is in the tank
    What concentration is the glycol
    What will the primary circuit flow rate be in kg/s
    What will the secondary flow rate be in kg/s
    etc
    If you are into a bit of calculation then you could start here...
    http://en.wikipedia.org/wiki/Heat_transfer_coefficient
    also
    http://www.eng-tips.com/viewthread.c...=171100&page=1
  1. Water Chiller
    By lana in forum Technical Speculations
    Last Post: 23-06-2007, 01:19 AM
  2. Water chiller help
    By ultralo1 in forum Trouble Shooting
    Last Post: 12-05-2007, 11:52 AM
  3. Connecting Trane Water chiller to air handling unit
    By celtictech in forum Fundamentals
    Last Post: 08-03-2007, 06:14 PM
  4. Water Chiller Control
    By David PS in forum Air Conditioning
    Last Post: 29-08-2006, 11:14 PM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
