    Apr 2002
    london
    70
    Cooling tower water pumps
    Can anyone give me any information or recommend a good read on cooling tower water pumps? I just want to know what to look for in regards pressure readings across them and flow rate calculations per size of pump etc.
    Reggie, are you talking about the condenser water flow through the tower or the tower water circulating pump ?
    If it is the tower pump itself I would have thought that the flow rate is more dependent on the discharge nozzles. The pressure at the nozzle is a meaningless figure unless you know what it should be (sounds obvious I know but ...). Nozzle fouling then starts to get involved as well... and so it goes.
  1. cooling water TDS
    By afeef in forum Technical Speculations
    Last Post: 19-04-2009, 07:38 AM
  2. cooling tower without fillings
    Last Post: 27-12-2005, 12:55 AM
  3. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Industrial
    Last Post: 14-10-2005, 06:34 PM
  4. Cooling tower evaporation, blowdown, makeup and cycles
    By miltbeychok in forum Fundamentals
    Last Post: 13-10-2005, 05:14 AM
  5. Building a wine cabinet
    By Rory in forum Technical Discussions
    Last Post: 13-07-2004, 08:28 PM
