    Jul 2005
    uk
    43
    Pipe sizes help !!!!!!
    Hi i have to order armou flex for refrigerant pipes but i only know the pipe sizes in mm what is the pipe sizes for 1/4" to 1.3/8" in mm
    Moscow
    40
    82
    Re: Pipe sizes help !!!!!!
    Hi, mig.
    1/4" = 6.35 mm, 1.3/8" = 4,13 mm.
    Jul 2005
    uk
    43
    hi thanks so 1/4 = 6.35 mm
    3/8 = 4.13mm
    what does 1/2"= ?
    5/8"= ?
    3/4 = ?
    7/8= ?
    1 and 1/8 =?
    1 and 3/8 = ?
    thanks
    Aug 2007
    NZ
    56
    3/8 = 9.5mm
    1/2 = 12.7mm
    5/8 = 15.9mm
    7/8 = 22.2mm
    1 1/8 = 28.5mm
    1 3/8 = 35mm
    Moscow
    40
    82
    Mig, 1 inch=25.4 mm. You can convert ewery lenght, if you know this.
    Mar 2007
    uk
    120
    For insulation buying purposes use the following sizes for when ordering.
    1/4 = 6mm x wall thickness Class 'O'
    3/8 = 10mm x wall thickness Class 'O'
    1/2 = 12mm x wall thickness Class 'O'
    5/8 = 15mm x " "
    3/4 = 20mm x " "
    7/8 = 22mm x " "
    1 1/8 = 28mm x " "
    1 3/8 = 35mm x " "
    Unless the pipe work is going through an area with extreme temperatures i would recomend 13mm wall thickness for AC aplications.
    Hope that info helps
    It's getting a bit desperate out there if someone has to search the web to do a basic and simple number unit conversion.
    If all else fails ask your supplier or look in the book - jeeesuus
    3,853
    Try asking for 4/8ths pipe at the wholesalers, after 5 minutes of searching in the catalogue they will tell you they don't sell it ( your coffee will now be at drinking temperature) say you will take 1/2" instead but it just isn't good enough!
    Aug 2001
    1,046
    Numbers and punctuation remain a closed book for some folk, Brian.....
    leeds
    Its even more desperate when someone like you logs on to post a message with no posative reply,you tit!!
    ebarran's Avatar
    ebarran Guest
    Mig, I am new in RE, but want to say there are standards for tubing and pipe sizes .
    Consult ASHRAE Fundamentals Handbook for nominal equivalent diameters.
  1. york YKHC 30FS pipe sizes
    By al in forum Air Conditioning
    Last Post: 16-07-2007, 11:09 PM
  2. Reducing Pipe Sizes
    By Clivo in forum Air Conditioning
    Last Post: 12-05-2007, 07:09 PM
  3. Replies: 17
    Last Post: 25-08-2003, 09:56 PM
  4. Pipe sizes
    By benncool in forum Chit Chat & Service Stories
    Last Post: 08-07-2003, 10:58 PM
