Results 1 to 1 of 1
Thread: lennox fault code
01-02-2008, 09:13 PM #1
lennox fault code
Hoping someone could shed some light on this fault code on a lennox unit.
Unit is gas heat/ cooling system. Every so often unit faults on code 13. (inlet or room t. Temp to low.) Controller is a dc 50 comfort. Condensing unit is BGK070HD Could anyone shed some light what could cause this code. Any one who works with lennox may find this a simple one? Just been out to the unit its pitch black where the unit is so will probably go back tommorow if i have time. Thanks guys
A6 Fault Code Problem
By markcubed in forum Air ConditioningReplies: 3Last Post: 29-12-2007, 11:29 AM -
mitsubishi city multi fault code
By robin r33 gtr in forum Air ConditioningReplies: 5Last Post: 05-11-2007, 10:23 PM -
UA Daikin Fault Code
By jedi in forum Air ConditioningReplies: 2Last Post: 23-07-2007, 01:44 PM -
Diplomat 6528 Fault Code
By Targus in forum DomesticReplies: 3Last Post: 31-10-2006, 07:43 PM -
Fault Code Sheets...?
By C_Henderson in forum Air ConditioningReplies: 2Last Post: 01-08-2006, 05:19 PM
