Results 51 to 58 of 58
Threaded View
20-12-2007, 10:26 PM #26
Re: liquid overfeed system design guide
Hiya Lana, i work in a large Refrigerated depot with 3 seperate R22 overfeed systems doing +7c, +3c and -20c running on stal open drive recips. I've got some technical specs for design and sizing for surge drums from the 1970's which are really indepth. All run on a saturated design temp of +35c with single stage compression. Each compressor has an individual oil seperator plus an oil seperator in common discharge. If you need an info send me a post
Daikin fault codes
Autocascade refrigeration system: design verification needed
By DaBit in forum Technical SpeculationsReplies: 3Last Post: 07-02-2010, 07:48 AM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM
